disc brake conversion
Yes. You do not have a proportioning valve now. You have a distribution block. You should go ahead and mount the proportioning valve on the top of the frame in case you decide to install headers one day if you don't have them already.
Combo valve (replaces distribution block) (note this brass one is aftermarket, factory ones were cast iron):
In-line proportioning valve (requires distribution block):
In 69 they used a hold off valve next to the MC and the non-proportioning distribution block on the frame. Pretty sure 68 was the same. The combo block does the same function with less parts but don't know if being more factory correct is important to you.
The MC also had bleeders that were not on the later cars.
Mocephus
Oct 1, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
