disc brake conversion
Old Jul 27, 2015 | 08:48 PM
olds68442's Avatar
I'm converting front drums to disc brakes do i need to replace the proportioning valve
Old Jul 27, 2015 | 08:52 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Yes. You do not have a proportioning valve now. You have a distribution block. You should go ahead and mount the proportioning valve on the top of the frame in case you decide to install headers one day if you don't have them already.
Old Jul 27, 2015 | 08:54 PM
olds68442's Avatar
Thanks for the information i do have headers so ill mount it on top of the frame..now i eliminate the distribution block right
Old Jul 28, 2015 | 06:34 AM
If you are using the combination valve, as used on the 1971-up cars, this combines the functions of the proportioning valve and the distribution block into one item and thus replaces the original distribution block. If you are using an aftermarket in-line prop valve only, the distribution block remains. Either way works - your call on how to do it.
Combo valve (replaces distribution block) (note this brass one is aftermarket, factory ones were cast iron):
In-line proportioning valve (requires distribution block):
Old Jul 28, 2015 | 08:33 AM
hookem horns's Avatar
In 69 they used a hold off valve next to the MC and the non-proportioning distribution block on the frame. Pretty sure 68 was the same. The combo block does the same function with less parts but don't know if being more factory correct is important to you.
The MC also had bleeders that were not on the later cars.
Old Jul 28, 2015 | 08:44 AM
1967-1970 disc brake cars all used a similar external metering valve. Repros are available, though the brass combo valve is a less expensive and better alternative, as it won't rust internally.
Old Jul 28, 2015 | 03:13 PM
olds68442's Avatar
proportioning valve
I have the brass aftermarket valve it came with the kit I bought.
this is all new to me is it easy to change out the master cylinder and brake booster and proportioning valve?
Mocephus
Oct 1, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
ricardo
Jul 27, 2010 05:26 AM
68droptop
Mar 31, 2009 06:10 PM
Want-A-Vert
Jan 4, 2007 07:19 AM
