Not sure what the problem is :(
The last few weeks the car has driven perfectly. Yesterday as well. This morning I took her out of the driveway and down the street and it felt like she had a flat tire. The front right tire feels like its wiggling exactly the way a flat tire feels but the tire isnt flat. I hear something when I turn but I don't see anything loose or broken. What could it be? I didn't drive it, I put her in the garage right away.
Whoever did the work should back it up! And pay for they tow if they did screw up, call them!
I had a 1970 with front drum brakes and it was making a creaking noise that I couldn't figure out until I took the hubs off. The inner race had cracked and dug into the hub cuasing the hub to move around and necessitating it's replacement.
:) "Whats goin' on with my Oldsmobile Cutlass?"
Took it to a wheel place today, the right front wheel had 1 broken lug and the wheel was off center. Got it replaced and centered correctly, and just checked the right left to check it and ALL the lugs were loose! Had everything removed, cleaned the brakes and tightened and recenter the wheels. Driving perfect now! Thanks everyone!
Thanks BlueRayWhale! I just moved here dont know where Carson City is.
"Again, justagirlfromla. You're welcome"
hahaha
welcome justa
sweet looking 70 love the colors X9 on the wheels I vote for SSIs
lugnuts - BTDT never again thx Baltimore beltway Friday night heavy but fast traffic 74 Cutlass Salon 70mph LR wheel bails, sparks, bouncing tire down 95 etc etc etc
anyway, welcome!
welcome justa
anyway, welcome!
Hey Lady long time no see anyways have not read this yet, If you plan on keeping the wheels....WHICH ITS YOUR DECISION AND NO ONE ELSE'S, any ways with them wheels make sure you check them lugs on a weekly basis.
And enjoy that small block 350 as much as you can with the sunshine out there
Better yet have all the studs replaced with 1/2" studs. 7/16" studs are borderline in a stock application lot alone wheels with 3 + times the weight of factory. You are begging to have a wheel fall off with stock studs.
yea I would assume if they put that big of wheel on there they would have done that but if its loose in that little of time after buying it, I would guess it wasn't, and any local tire shop can change them out for you its not hard just time consuming
You would be amazed how many people upgrade wheels and tires and never do anything with studs, brake, suspension, and gear ratio.
Then wonder why the car doesn't perform the way it should.
nukesec1
February 10th, 2010 10:10 AM
