Not sure what the problem is :(
Old Mar 27, 2010 | 08:07 AM
justagirlfromla's Avatar
The last few weeks the car has driven perfectly. Yesterday as well. This morning I took her out of the driveway and down the street and it felt like she had a flat tire. The front right tire feels like its wiggling exactly the way a flat tire feels but the tire isnt flat. I hear something when I turn but I don't see anything loose or broken. What could it be? I didn't drive it, I put her in the garage right away.
Old Mar 27, 2010 | 08:36 AM
Don L/442's Avatar
Wheel bearing may have play(loose) or failed.
Old Mar 27, 2010 | 08:57 AM
lshlsh2's Avatar
71 cutlass convertible
Also check the front suspension.
Larry
Old Mar 27, 2010 | 09:01 AM
the suspension is all new and isnt loose. I'll have to take it to a shop to check it out i guess. Can I damage it more by driving it a few blocks to the shop?
Old Mar 27, 2010 | 09:14 AM
Bluevista's Avatar
Registered
This may sound too obvious but check to make sure the lug nuts are tight on that one and the rest of the wheels if you haven't yet.
Old Mar 27, 2010 | 09:40 AM
If it starts to pull hard in one direction your wheel bearing could be seizing up and it could become impossible to drive.
Old Mar 27, 2010 | 10:19 AM
wmachine's Avatar
Trying to remember member
You can't presume that it isn't a problem with the new suspension. That is not an unusual presumption, but there could be a problem with the parts and/or the installation. Personally, I wouldn't chance driving it more. Without knowing more about the problem, yes it is possible for more damage.
Whoever did the work should back it up! And pay for they tow if they did screw up, call them!
Old Mar 27, 2010 | 10:29 AM
Aron Nance's Avatar
X's2 on the lug nuts, and rechecking front suspension!!!!!
Old Mar 27, 2010 | 10:38 AM
svnt442's Avatar
I had a 1970 with front drum brakes and it was making a creaking noise that I couldn't figure out until I took the hubs off. The inner race had cracked and dug into the hub cuasing the hub to move around and necessitating it's replacement.
Old Mar 27, 2010 | 10:40 AM
blueRAYwhale's Avatar
Smile :) "Whats goin' on with my Oldsmobile Cutlass?"
justagirlfromla,blueRAYwhale in Carson City says Hi. Find a ASE certified mechanic familiar with vintage 70's GM cars, and take it to them. Diagnosing problems like this is difficult and you're going to need a good mechanic to keep that car on the road anyways.
Old Mar 27, 2010 | 11:22 AM
agtw31's Avatar
get rid of that air cleaner.
that foam will disintegrate from gasoline exposure and your carb will suck it down in your motor.
Old Mar 31, 2010 | 04:38 PM
Took it to a wheel place today, the right front wheel had 1 broken lug and the wheel was off center. Got it replaced and centered correctly, and just checked the right left to check it and ALL the lugs were loose! Had everything removed, cleaned the brakes and tightened and recenter the wheels. Driving perfect now! Thanks everyone!
Thanks BlueRayWhale! I just moved here dont know where Carson City is.
Old Mar 31, 2010 | 05:31 PM
Smile "Again, justagirlfromla. You're welcome"
, It's northwest of Las Vegas about 450 miles, close to Lake Tahoe, near Reno. It's the Capitol. If you picture Nevada as sort of a rectangle with the lower left corner cut-off at a thirty degree angle or so, Lake Tahoe(CA/NV), is where the angle meets the left side. And it's a rectangle not a block, small or otherwise
Old Mar 31, 2010 | 09:21 PM
jeffreyalman's Avatar
hahaha
welcome justa
sweet looking 70 love the colors X9 on the wheels I vote for SSIs
lugnuts - BTDT never again thx Baltimore beltway Friday night heavy but fast traffic 74 Cutlass Salon 70mph LR wheel bails, sparks, bouncing tire down 95 etc etc etc
anyway, welcome!
Old Apr 1, 2010 | 04:46 PM
Smile :) "That's right" :)
Old Apr 1, 2010 | 07:01 PM
Limey's Avatar
Hey Lady long time no see anyways have not read this yet, If you plan on keeping the wheels....WHICH ITS YOUR DECISION AND NO ONE ELSE'S, any ways with them wheels make sure you check them lugs on a weekly basis.
And enjoy that small block 350 as much as you can with the sunshine out there
Old Apr 1, 2010 | 07:06 PM
gearheads78's Avatar
car guy
Better yet have all the studs replaced with 1/2" studs. 7/16" studs are borderline in a stock application lot alone wheels with 3 + times the weight of factory. You are begging to have a wheel fall off with stock studs.
Old Apr 1, 2010 | 07:10 PM
Limey's Avatar
yea I would assume if they put that big of wheel on there they would have done that but if its loose in that little of time after buying it, I would guess it wasn't, and any local tire shop can change them out for you its not hard just time consuming
Old Apr 1, 2010 | 07:32 PM
70 cutlass s's Avatar
You would be amazed how many people upgrade wheels and tires and never do anything with studs, brake, suspension, and gear ratio.
Then wonder why the car doesn't perform the way it should.
Old Apr 9, 2010 | 12:14 AM
64Super88's Avatar
Rich from Las Vegas
I could have loaned you a jack...
rocket350
Dec 4, 2012 02:39 PM
442much
Non-Olds Engines
Dec 3, 2010 06:53 PM
Limey
Sep 21, 2010 04:27 PM
russell7088
Aug 23, 2010 10:18 PM
nukesec1
Feb 10, 2010 10:10 AM
