master cylinder upgrade question
Old August 3rd, 2012, 05:54 AM
lowkey235's Avatar
I want to upgrade my 1966 toronado to a dual master cylinder after an incident with a blown line and no brakes, thats a lot of car to stop with your feet, thankfully it was in a parking lot. I have searched the forums and my conclusion is I can use the booster and master cylinder from a 1967 toronado with out any issues, am I correct? this is a front drum rear drum configuration. I am a little nervous so am looking for someone objective to tell me if i am right.
p.s. I tried the toronado forum first but not much activity there.
lowkey235 is offline
Old August 3rd, 2012, 09:50 AM
Run to Rund's Avatar
yes. Also you need to rework the brake lines; in 66 all of them go to a junction block and then one line goes to the master cylinder (mc). You need the front lines to go to one end and the rear line to go to the other port of the mc. It might be easiest to remove the rear line, get a coupler and a short line for it to reach the mc. You can plug the port in the junction you just took the rear line off. Special plugs are available at parts houses. You can also get the big nuts and short adapter lines to go to the mc.
Run to Rund is offline
Old August 3rd, 2012, 11:34 AM
You'll need the M/C and power booster for a 67. The single circuit M/C used a longer pushrod between the booster and M/C than the dual circuit M/C.
joe_padavano is offline
Old August 3rd, 2012, 11:57 AM
lowkey235's Avatar
thanks for the good info.
mbat
Brakes/Hydraulic Systems
April 12th, 2021 07:40 AM
lowkey235
October 1st, 2015 05:57 AM
1Fastolds
Ninety-Eight
June 9th, 2014 09:12 PM
denf221
November 16th, 2010 02:04 PM
54olds
December 16th, 2007 06:52 AM
Quick Reply: master cylinder upgrade question
