master cylinder upgrade question
Old Aug 3, 2012 | 05:54 AM
lowkey235's Avatar
I want to upgrade my 1966 toronado to a dual master cylinder after an incident with a blown line and no brakes, thats a lot of car to stop with your feet, thankfully it was in a parking lot. I have searched the forums and my conclusion is I can use the booster and master cylinder from a 1967 toronado with out any issues, am I correct? this is a front drum rear drum configuration. I am a little nervous so am looking for someone objective to tell me if i am right.
p.s. I tried the toronado forum first but not much activity there.
Old Aug 3, 2012 | 09:50 AM
Run to Rund's Avatar
yes. Also you need to rework the brake lines; in 66 all of them go to a junction block and then one line goes to the master cylinder (mc). You need the front lines to go to one end and the rear line to go to the other port of the mc. It might be easiest to remove the rear line, get a coupler and a short line for it to reach the mc. You can plug the port in the junction you just took the rear line off. Special plugs are available at parts houses. You can also get the big nuts and short adapter lines to go to the mc.
Old Aug 3, 2012 | 11:34 AM
You'll need the M/C and power booster for a 67. The single circuit M/C used a longer pushrod between the booster and M/C than the dual circuit M/C.
Old Aug 3, 2012 | 11:57 AM
lowkey235's Avatar
thanks for the good info.
mbat
Brakes/Hydraulic Systems
Apr 12, 2021 07:40 AM
lowkey235
Oct 1, 2015 05:57 AM
1Fastolds
Ninety-Eight
Jun 9, 2014 09:12 PM
denf221
Nov 16, 2010 02:04 PM
54olds
Dec 16, 2007 06:52 AM
