Inline Tube disc brake conversion On 1972 cutlass
Old Mar 29, 2018 | 10:31 AM
Oldssupreme's Avatar
Chris
Hi! Does anyone have a photo they can share of the MBM drum to disc brake conversion kit, the non-factory correct one where the proportioning valve is mounted at the master cylinder? I specifically need a photo of how the proportioning valve mounts to or near the master.
Also I installed the inline tube rear drum set and noticed there is nowhere for me to access the adjusting sprocket, where that little rubber piece was is just indented metal. Are these self adjusting or am I missing something? Thank you!
Chris
Old Mar 29, 2018 | 12:21 PM
Chris
The indented metal is supposed to be a knockout. Most brake hardware kits come with the rubber plugs.
Old Mar 29, 2018 | 01:36 PM
Chris
Hi Joe. Okay. So I just need to take a small hammer and chisel and knock it out?
Old Mar 30, 2018 | 08:05 AM
oddball's Avatar
Yup, just knock it out. It should be mostly cut so you can. If not, call MBM and ask them WTH. They've been pretty good to work with in my experience.
For the prop valve, that setup is the more common Chevy configuration. You can look up just about any pic of a chevy or any aftermarket ad. There should be an L-shaped bracket in the kit. Put the master on the booster, then slip the bracket over the outboard stud. The prop valve mounts onto the bracket right under the master, then there should be some little stubby tubes to go from the master to the prop.
You can also move the prop down to the stock location, but you'll need Olds-style tubes. FWIW, the stainless tubes aren't worth it. The bends from all the manufacturers are terrible, and the stainless are almost impossible to fix and will leak if they're not made just right.
Old Apr 5, 2018 | 06:36 PM
Chris
Oddball, thanks for your message. I'll give this a try although it seems as though my prop valve's bolt mounting holes are set on an angle in reference to the bracket and the master whereas the Chevy ones I've seen online seem to be parallel with the bracket and the master. Its hard to figure where to start having so many of these short stubby lines.
Thanks!
Chris
Old Apr 5, 2018 | 07:44 PM
Dave26's Avatar
The short stubby lines you referenced have different sized fittings that will only fit one way. BTW it’s helpful to not tighten the prop valve and bracket nuts until the line fittings are threaded.
Mocephus
Oct 1, 2021 09:45 AM
68442Convertible
Brakes/Hydraulic Systems
Jun 8, 2016 08:15 PM
Maverick
Jun 26, 2013 08:21 AM
Big red72
Apr 8, 2013 09:14 AM
59-59-59
Feb 8, 2011 09:03 AM
