Front Drum Brake Backing Plates 1969 442
Old Jun 18, 2012 | 06:30 PM
501Paratrooper's Avatar
I've replaced the front drums with discs. I'm having a tough time removing a drum from the plate, it is not attached to the car it is basically from the spindle outward. The wheel adjuster is trashed.
Are these worth the trouble to get apart, clean up and sell or should I just toss them?
Old Jun 20, 2012 | 09:42 AM
Sounds like the shoes have worn a lip in the drum and you won't be able to remove the drum without backing off the adjuster. What I've done in situations like this is to grind off the heads of the two brake shoe retainer pins. This loosens the drums and you'll eventually be able to get the drum worked off. The spindles can be easily converted to disk spindles and the drum hubs are useful for mounting 12" Corvette rotors as a brake upgrade.
Old Jun 20, 2012 | 11:35 AM
Thanks Joe!
monzaz
Jan 4, 2015 02:48 PM
Flye
Jun 6, 2012 10:52 AM
lvelocci
Brakes/Hydraulic Systems
Oct 24, 2010 02:58 PM
oldzy
Oct 8, 2010 03:08 PM
oldzy
Oct 5, 2010 03:39 PM
