Dust shield and caliper bracket
Old August 27th, 2017, 05:18 PM
Cutlasskyle's Avatar
My new spindles and the parts arent quite lining up together . Dust shield and bracket came off of a 72 442 and are so close to bolting together on my Cutlass S. Is it ok to drill or shave the bracket upper bolt hole to allow the bolt to line up . Or should I break down and buy a new bracket and shield .
Cutlasskyle is offline
Old August 27th, 2017, 05:33 PM
DJS70cutlass's Avatar
Will the bracket bolt up without the shield? If not it kinda makes me think the bracket is a bit tweaked. Is the bottom bolt loose enough when trying to start the top bolt?
DJS70cutlass is offline
Old August 27th, 2017, 05:51 PM
Ill try it without the dust shield . I started with just the top but bottom one wouldn't even attempt to go through . Then I put bottom ones in and top was closer but I dont wanna try to force it . Bottom bolts were loose and tried it with them tight as well to see if it help align it .
Old August 27th, 2017, 06:23 PM
Tried without dust shield no luck . Moved to passenger side to see if it was maybe just warped driver side parts same thing. I believe its the spindles now cause both sides . Which sucks cause I just put all new ball joints in and dont wanna do that again but I may have to .
Old August 27th, 2017, 07:16 PM
Ordered parts from speedway motors p/n# 910-34900
Old August 30th, 2017, 07:44 AM
Has to purchase new brake caliper mounting brackets and dust shield hole werent exact spacing .
shamusj
Brakes/Hydraulic Systems
November 17th, 2023 03:47 PM
doc
February 8th, 2012 10:49 AM
jpc647
November 17th, 2011 06:21 AM
68conv455
October 9th, 2009 06:49 PM
Quick Reply: Dust shield and caliper bracket
