Swap 4 piston caliper to single piston - dust shields and brackets...
Old Nov 24, 2016 | 08:42 AM
shamusj's Avatar
Happy Thanksgiving!
It's been a long time since I've worked on my car-
The car has been sitting for decades- all serviceable brake components are frozen or trashed....currenlty have the two piece rotors and 4 piston calipers- I'm not worried about 100% stock look so I think it's best to roll my system to a single piston set up.
Main question I have- will the dust shields from my 4 piston calipers work with the single piston set up?
Caliper brackets - anybody have a set of cheap used ones?
I'll be using the old spindles (I think they will work) and updating to one piece rotors.
Regarding plumbing- my car currently has a hold off valve attached to the master cylinder (per original)- unless theres a smarter way to go- I will simply buy a new master cylinder, new hold off valve and replace the front lines using inline tube. If there's a better way- I'm wide open.
Any help or guidance would be appreciated.
Old Nov 24, 2016 | 11:04 AM
2blu442's Avatar
I'm not positive which parts will interchange. But if your parts are usable as cores to someone wanting the early style you might want to keep all the 4 piston parts together. It might be easier to sell/trade your system for the newer single piston setup. I know I've encountered the 4 pistons setups on both 1967 and 68 Cutlass/442.
On the master cylinder, you could keep the proportioning valve that's bolted to the booster or you could swap out and use the 1971 and newer that has a combination valve. Both the proportioning valve and distribution block are combined in one.
I really like this thread Joe created discussing the front disc brakes. If you have time I'd encourage you to read through it. John
https://classicoldsmobile.com/forums...sk-brakes.html
Old Nov 24, 2016 | 06:23 PM
allyolds68's Avatar
Originally Posted by shamusj
Happy Thanksgiving!
The single piston calipers bolt right up. I did the exact same swap. Everything fits. I even used the old hold off valve and distribution block. The only thing I bought was a master cylinder because my old one was junk and the calipers. I bought everything from an auto parts store. Nothing was sourced from a restoration place.
Old Nov 25, 2016 | 06:57 AM
I assume you mean that the brackets for the single piston calipers bolt right up. The brackets themselves are completely different. The spindles, however, are the same.
Four piston caliper brackets:
Single piston caliper brackets:
Old Nov 25, 2016 | 07:16 AM
allyolds68's Avatar
Yes
Old Nov 25, 2016 | 04:14 PM
Yellowstatue's Avatar
Seems to me that the splash shields are different. 1381722-138123 '67 &'68...5463566-5463565 '69-'72.
Old Nov 25, 2016 | 04:42 PM
Given the difference in bracket and caliper size, I would have thought that.
Old Nov 17, 2023 | 03:47 PM
shamusj's Avatar
This old post just answered my new questions....thanks!
Rocketbrian
Feb 19, 2015 07:10 PM
oldzy
Jun 5, 2012 11:04 PM
doc
Apr 11, 2012 08:25 PM
doc
Feb 8, 2012 10:49 AM
