Disc Rotors have races installed?
Old February 19th, 2011, 04:35 PM
oldzy's Avatar
It has been so long since I have replaced rotors/wheel bearings.... do new rotors have the wheel bearing races already installed? If so, what is the orientation? Tapered end inwards?
oldzy is offline
Old February 19th, 2011, 04:53 PM
OLDSRALLYE350's Avatar
Yes the new rotors come with the races installed. They are installed so the small end of the bearings goes into the rotor. You should be able to see the races in the rotor and test seat the bearings into the racw=es before installing .Need to replace the seals on the backside when the bearings are installed.
OLDSRALLYE350 is offline
Old February 19th, 2011, 06:23 PM
oldzy's Avatar
Ok. So I don't have to use the races included with the bearings. Thx.
oldzy is offline
68 D88
66
August 28th, 2021 06:58 AM
Curts1970cutlass
Brakes/Hydraulic Systems
September 26th, 2014 12:08 PM
Oldssupreme
February 21st, 2013 10:24 AM
oldzy
March 23rd, 2011 07:45 PM
oldsmobilia
April 18th, 2010 07:43 AM
Quick Reply: Disc Rotors have races installed?
