Cutlass rear disc brake conversion
Old Dec 9, 2007 | 10:27 AM
ricardo's Avatar
i got a 1987 Cutlass salon i want to due a rear disc brake conversion on a budget any one ever done this let me know
Old Jul 25, 2010 | 06:48 PM
veltboy618's Avatar
Is there a conversion for the rear out there?
Old Jul 25, 2010 | 07:22 PM
67442nut's Avatar
The aftermarket kits are fairly expensive, at least for the good ones.
If you're doing an "economy" coversion, you can use rear disc brake set ups from a number
of GM cars including Camaros, Firebirds and several late '80's and early '90's GM full size cars.
There probably others I don't know about.
I have some off a 20?? SS Camaro that I haven't installed on anything yet.
They look kinda small, but I'm sure they're better than a drum set up.
Old Jul 25, 2010 | 11:48 PM
Aceshigh's Avatar
The cheapest is the S10 brake conversion if you want a parking brake.
The next cheapest is the LS1 F-body rear disc if you don't want a parking brake.
Here's the info on the swap. Firechicken lists all the parts.
The backing plates is the biggest concern for your specific rear end.
Obviously you have to make sure these fit the rims you have, but most guys I know upgrade their rims.
http://www.nastyz28.com/forum/showth...t=94303&page=5
Yes, it's a Chevy site......suck it up if you want to do it inexpensively.
Old Jul 26, 2010 | 05:41 AM
TripDeuces's Avatar
http://scarebird.com/
Try this place. Relatively cheap and he gives you a list of the NAPA parts that will work with the kit. I doubt you'll spend $300 on the whole thing. http://www.speedwaymotors.com/default.aspx might have a kit also but around $450
Old Jul 26, 2010 | 07:33 PM
Aceshigh's Avatar
Where exactly is this parts list ??? I can't find it anywhere on his site for his 87 or my 70.
I want to see what kind of calipers he's using on these to see what size pistons they are.
Old Jul 26, 2010 | 07:39 PM
TripDeuces's Avatar
My parts list came with the set up but I remember for the rear they were Caddy calipers with e-brake, this was for a 12 bolt Chevy. Was even cheaper on Evilbay.
Old Jul 27, 2010 | 03:54 AM
Aceshigh's Avatar
All the stuff I've seen on ebay is low caliber quality stuff.
Here's a very informative write up I found on Car Craft comparing the Caddy calipers to newer 4th gen Fbody one's.
http://www.carcraft.com/howto/ccrp_0...cket_bolt.html
I still have to swap out my 10 bolt rear drums on my 78z, so this piqued my interest.
Old Jul 27, 2010 | 05:26 AM
TripDeuces's Avatar
I still have the kit so let me dig it up and look. I'll do it later today.
Mocephus
Oct 1, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
Mike Hateful
Oct 3, 2011 06:58 PM
WheaYat
Mar 25, 2010 09:52 AM
nh4kidsdad
Feb 12, 2009 04:49 AM
