Broken Wheel Stud- Need Advice
Old Jun 21, 2025 | 11:23 AM
69 Hurst's Avatar
Olds Fanatic
Hi Guys,
I need to replace a broken front wheel stud on the H/O and was looking for some direction on how to separate the hub from the rotor after removing the five bolts that hold them together. Any help is greatly appreciated!
Old Jun 21, 2025 | 01:43 PM
You don't need to separate the hub to replace the one stud.
Old Jun 22, 2025 | 03:55 AM
The studs are what hold the hub to the rotor. Simply replace the single broken stud. Problem solved.
Old Jun 23, 2025 | 05:54 AM
69 Hurst's Avatar
Olds Fanatic
Thanks guys. I should have provided more detail in my opening post. This is a two piece hub and rotor, I cannot replace a wheel stud without separating them. I removed the bolts holding them together from the rear, but need a way to separate them.
Old Jun 23, 2025 | 06:01 AM
One more time. The knurls on the studs are what is holding the rotor to the hub. Reinstall the bolts between the hub and the rotor and simply press out the broken stud. Separating the two requires you to press out ALL FIVE studs. Knock yourself out if you believe you must do that.
Old Jun 23, 2025 | 07:40 AM
69 Hurst's Avatar
Olds Fanatic
Joe,
I really appreciate your help and I'm not trying to be stubborn, but there is no way to remove or replace a wheel stud without separating the two (see pic) as the head of the stud hits the crown of the rotor. from what I can tell, the wheel stud knurls have nothing to do with holding the hub and rotor together.
Old Jun 23, 2025 | 07:52 AM
Originally Posted by 69 Hurst
Joe,
In that case you will need to break loose the rust between the rotor and the back of the hub. I would suggest supporting the rotor as close to the hub as possible to prevent bending it and press on the hub where the seal sits.
Old Jun 24, 2025 | 05:36 AM
69 Hurst's Avatar
Olds Fanatic
Thanks Joe, appreciate it.
Old Jun 24, 2025 | 05:56 AM
Andy's Avatar
Soak the crap out of it with penetrating oil for a couple hours, then follow Joe’s advice..may loosen the rust a bit
Old Jun 24, 2025 | 09:28 AM
69 Hurst's Avatar
Olds Fanatic
Thanks Andy.
Old Jun 24, 2025 | 11:32 AM
Might be able to let it sit in the sun, then dump some dust off nitrogen propellant on just the hub, then smack hub with hammer
Old Jun 24, 2025 | 04:10 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
And if you're going through all that why not replace the other 4?
I'm from the camp if you're in there do it.
Why did the one stud break? Did the others get the same stress and were stretched to (almost) yield?
Safety.
There is a good source for C of A studs.....ARP. Definitely don't cheap out here.
Old Jun 25, 2025 | 06:10 AM
69 Hurst's Avatar
Olds Fanatic
Safety.
Not sure what caused a single break, but I am definitely replacing all five. Thanks for the feedback!
mike 66 toro
Dec 6, 2023 05:45 PM
ericisback
Wheels and Tires
Sep 8, 2022 07:10 AM
Sven_Olds69
Feb 14, 2021 03:36 PM
Bluemeanie
Wheels and Tires
Feb 28, 2013 08:58 PM
The Stickman
Mar 16, 2010 07:34 PM
