brakes dilemma
Old Aug 14, 2018 | 01:02 PM
DLP's Avatar
DLP
brakes dilemma
I currently have pending master cylinder replacement that needs to happen.
The car is a 67 Cutlass Supreme/442 with manual all drums.
I'm on an extremely tight budget.
My question is, should I just keep the manual setup, or should I opt for a power booster also?
I know some of you would probably tell me to just upgrade to disc brakes but financial issues don't make it possible right now.
Thanks in advance,
DLP
Old Aug 14, 2018 | 01:04 PM
If you're on a budget why even consider changing the brakes on your Cutlass? Just install new shoes, have the drums turned and repair the master cylinder. It's been stopping fine for years, right?
Old Aug 14, 2018 | 01:17 PM
DLP's Avatar
DLP
brake dilemma
Up until now she's been stopping fine.
I noticed the problem on the way home from the last car show.
When I got home I checked the master cylinder and it was darn near empty in the front reservoir and 2/3 full in the rear.
What was left in the front was about 1/4 inch of sludge.
I guess I'm pretty lucky to have made it home without incident.
Old Aug 14, 2018 | 03:11 PM
Normally when the reservoir is near empty and there are no visible leaks around the master cylinder the issue is not the master cylinder but wheel cylinders. If there was no vibrations when applying the brakes there is no need to cut the drums even if replacing shoes and wheel cylinders.
Old Aug 14, 2018 | 04:47 PM
RandyS's Avatar
Wheel cylinders are very inexpensive, and pretty easy to change out. You can pull the drums and see if you have one (or more) leaking.
Old Aug 15, 2018 | 05:19 AM
If you had sludge in the brake lines make sure you bleed the brakes thorroughly after repairing the master cylinder.
Old Aug 15, 2018 | 05:42 AM
classicmuscle442's Avatar
To save time and cash you can buy a wheel cylinder hone and clean up your existing wheel cylinders. Depends on condition, not pitted/rusty. Wheel cylinders kits from rock auto are few bucks each.
bigred1972
Apr 15, 2015 03:18 PM
waterzap
Brakes/Hydraulic Systems
Jul 22, 2013 12:10 PM
Steve69
Sep 6, 2012 08:19 PM
68442CONVERTCO
Feb 25, 2012 11:21 AM
scrappie
Nov 18, 2007 06:41 PM
