Brake Upgrade help needed
I have a 1973 Cutlass S with a 403.
I am looking to upgrade the quality of the current brakes (F-disc/R-drum currently). I will stick with the current approach of disc/drum —Can anyone make a brand recommendation and source for parts?
While I have not tried this, you MIGHT be able to swap to the front spindles used on the 1977-1990 full size wagons, which have 12" rotors. The stock rotors on those cars have a 5 x 5" bolt circle, but you can get the rotors from a third gen Camaro with the 1LE brakes that are 12" with the correct 5 x 4.75" bolt circle.
