Brake line blues (part II)
Old May 10, 2014 | 08:33 AM
Chumley's Avatar
Scrapped trying to splice in a new section of line between proportioning valve and rear brake line. I ended up getting a new front to rear line. 6 hour job removing old and installing new. What took the longest was getting the bolt out on that clamp near the rear. You know, that one where the bolt head is sandwiched between the body and the frame, where you might as well be blind to try and get the wrench on it, while prying between the body and frame to even get the wrench in there? Yeah, that one. Why oh why, Mr. General Motors? Isn't crawling under the car with a 1/2 century plus body agony enough? Oh, that little plug in the body right above the bolt head. But that would mean taking the rear seat out to get to the plug. Another 2 hours of otherwise unnecessary labor. If only you were thinking 40 years out about the poor car guys who love working on these machines, but who have limited resources and anatomies older than the cars themselves. And on and on. Anyway, in hind sight, maybe someone has an easier way of getting that bolt out? When I did finally get it out, it was pretty probable it was not going back in, but the car gods were forgiving that day, and it dropped straight in and I got it started on the first couple of turns. Now I just need to bleed the lines and hopefully....but wait, that's another adventure. Chumley
Old May 10, 2014 | 09:25 AM
The back seat only takes a few minutes to remove, it snaps in place. Anyway glad you got it.
Old May 10, 2014 | 05:12 PM
Chumley's Avatar
The seat was easy to remove for reupholstery, but was a bear to get back in. Took me almost an hour to get both hooks seated. ( probably the extra thickness on the frame from the POR-15 treatment) Anyway, that's all part of GM engineering.
Del70
Dec 7, 2025 02:13 AM
Chumley
Brakes/Hydraulic Systems
23
Feb 23, 2014 11:51 AM
Maverick
Jun 26, 2013 08:21 AM
Bluemeanie
Nov 5, 2011 09:25 AM
68conv455
May 20, 2008 02:03 PM
