Brake pedal travel
Brake pedal travel
So I replaced the diverter valve on my '72 Supreme and all 4 corners bled good. Now it takes more pedal travel before the brakes engage. Before I would barely have to press the pedal to whoa it down, whereas now I have about 3/4 of the distance to the floor before I can feel the brakes. She stops good and when I'm in reverse and hit the brakes, I can feel the car rock backwards.
Before I replaced the valve I'm pretty sure the rears weren't engaging because my wheel cylinders were shot and the diverter valve had shifted. Is it possible that because no fluid was moving to the rear and only to the front it took less pedal travel, or do I need to adjust the rears more, or am I good?
FWIW
I'm not 100% certain if you changed anything on the rears? None-the-less, it may not be too far-fetched if those rear brakes haven't been used in a long, long time (since you admittedly haven't had any pressure going to the rears - right?) the arc of the rear shoes might not be matching the drum radius, deflecting the shoes somewhat. This gets better as the linings wear in to the drums. I'd probably drive it for a week or two before making further adjustments.
Dave - Diverter valve? You have a combination valve, buddy.
EDIT: I hit the Post button too quickly. I agree w/ Eric an adjustment might be needed; however, I (personally) would drive it a week or two, and (this is just me) would bleed the brakes again once or twice. That would be my first choice before adjusting since it's really, really easy to suspect air remains "somewhere".
FWIW
Oh, and thanks for the clarification on the valve nomenclature
Dave - I can't say w/ any degree of certainty if you'd have less pedal travel to be honest & I'd hate to speculate just to suggest I think it would be more or less pedal travel. I'd be patient with it - you haven't had rear brakes in some time. Increase the patience level a couple notches and drive it awhile before getting wrench-happy on it. Again, personally, I'd drive it then my first approach would be to bleed the brakes one more time before making adjustments. Your call. Glad you got the combo valve installed.
I can feel the star adjuster tension increasing.
You can also lift the car and remove the wheel you are working on so that you can manually rotate the drum/axle shaft. Adjust the shoes until you can feel the drum dragging when you rotate it.
You do realize you MUST have SOME drag when installing right? The rear wheels should NOT be able to free-wheel (spin). That's where to begin. If the rear wheels are freely spinning they need further adjustment. It should take just a little bit of strength for you to turn the wheels and they should NOT be able to spin. The only way they should spin is if you have to apply some force to make them spin.
UPDATE: I haven't done any adjustments since I started this thread because I wanted my buddy Mike to drive it and get his input. He came over today and in his opinion, all is good. He has a '69 Cutlass so I trust his judgment, so I'm calling it a wrap on the brake work.
I forgot to mention that I was wrong about the pedal travel. The pedal actually stops when it's about even with the gas pedal.
FWIW
https://itstillruns.com/properly-bre...s-7571495.html
Norm, out of curiosity, today I checked for wear on the new rear shoes and saw rubbing on the outside edges of the shoes, which means they are making contact with the drums. This would support your suggestion that they need to "wear in" to the drums. I've only driven it a couple times since I replaced the shoes, so I'm guessing more time behind the wheel is needed. After doing some research, I came across this, and wanted to ask if you've ever heard of doing this?
EDIT: I don't mean head in reverse at 30 miles per hour or pull a hole shot and slam on the brakes. Just rapidly go into reverse 6 - 7 times maybe 20' - 25'.
Dave - That's pretty much how I've always broken in drums from the first time I worked on drums (1969). The only thing missing is going in reverse 6 or 7 times and locking them up each time in reverse.
I just brake hard. If the tires lock up, don’t brake as hard the next time.
You can skip this process by using a tool to tighten the star adjuster as I posted earlier.
sschevellecutlass_Bob
Brakes/Hydraulic Systems
Mar 30, 2018 06:01 PM
Supernaut72
31
Mar 2, 2017 03:24 AM
steel
17
Nov 8, 2012 04:51 AM
