Bleed master cylinder?
Old May 1, 2012 | 04:06 PM
texasred's Avatar
Tom Servo's Stunt Double
I'm going to replace my master cylinder and bleed all brake lines (disc front, drum rear).
Is it necessary to bench bleed the master cylinder first? I never did before, but that was 4 wheel drums long ago in a far away galaxie (or maybe it was a Mustang)...
Is it still start bleeding at the furthest wheel from the MC and work my way closer?
TIA
C.J.
Old May 1, 2012 | 04:57 PM
Oh yeah. And it's got to be LEVEL when you do it.
Yeah, farthest to closest, but don't obsess about it.
Old May 1, 2012 | 08:48 PM
Nasty455's Avatar
XCELERATIONRULES!
Don't even think about installing the master without bench bleeding...you will be taking it back out and installing it again.
it's not that difficult..they make a kit,with fittings that attach to the out ports,and you submerge them in the filled master cylinder.
Actuate the master cylinder piston until all bubbles are removed.
I also install speed bleeders on the front...one man operation...open the bleeder and pump the pedal...bleeder has a one way check valve...awesome invention.
JCMC64
Brakes/Hydraulic Systems
Jul 22, 2013 09:00 PM
Bottoms
Oct 7, 2010 03:16 PM
Kidcutty
15
Apr 2, 2010 06:33 PM
84oldsDelta88
Dec 11, 2009 06:19 AM
68conv455
Sep 16, 2008 10:49 AM
