?? about new booster/master install with pics
1971 A body 4 wheel power drum brake system
As far as the rubber sleeve the new master cylinder and power booster are set up a little different than the old ones.
Will this new set up work together?
Do I need to use some white greese on the rubber sleeve? or the push rod with O ring?
How do you properly adjust the shackle on the threaded rod where it hooks to the pedal under the dash?
here's some pics of the old and new master and booster
thanks much for any help
I just did this not to long ago. All the pictures are such close ups I can't really get my bearings as to what's in relation to what.
As for adjusting the shackle on the threaded rod to where it hooks to the pedal under the dash, I just set the new one the same as the old one. Although I haven't been able to drive it yet to see if that actually worked or needs further adjustment.
My new power booster came with two rods, make sure you pick the right one!
Here's 4 more pics a little further from the subject,hope this helps.
I have it almost ready to put back together and want to get it done the right way the first time.
old master
old booster
new master
new booster
old master
old booster
new master
new booster
The Bug Man
Brakes/Hydraulic Systems
October 18th, 2014 07:04 AM
zodiacblueS
44
October 12th, 2014 03:22 PM
Del70
June 13th, 2011 03:41 AM
eddieunderground
November 26th, 2010 09:46 PM
