Booster? or Master?
Old Oct 7, 2008 | 10:05 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Booster? or Master?
Ok folks. Need an opinion or 2.
I replaced all the brake lines on my delta because I found one with a small pinhole, and bled the system accordingly. Brakes have been great for a few weeks now. However, at the last few stoplights on the way home today the pedal started to slowly sink into the floor. By the time the light changes from red to green the car starts to inch forward. I checked the fluid level and both reservoirs were equally full. fluid level was about halfway up to the top. I checked the bleeders and they are all closed. By the time I get to the next light, the brakes work again, and when stopped, starts to slowly sink again.
Booster?, or master?
Old Oct 7, 2008 | 10:17 PM
dan2286's Avatar
Is their any fluid leaking at the back of the master cylinder? Sometimes those like to leak after changing brake components. If not, their is some procedures in Haynes manuals to help diagnose this type of stuff, or if you have a factory service manual that would be your best bet.
Old Oct 7, 2008 | 10:38 PM
Master and booster had no visible fluid. and the lines were dry as well. Is it possible for the booster to suck in fluid if the master cylinder seal has blow by?
Old Oct 7, 2008 | 10:53 PM
dan2286's Avatar
I have never heard of that. You would at least have some type of indication of a vacuum leak. I think that a bad booster will give an extremely hard pedal, so maybe that will point you in the right direction.
Old Oct 8, 2008 | 02:09 AM
dynamic88's Avatar
SOUNDS LIKE THE SAME PROBLEM I HAD RECENTLY. IT WAS THE BOOSTER. I HAD TO HAVE IT REBUILT. CHRIS
Old Oct 8, 2008 | 03:29 AM
csstrux's Avatar
I had a similar problem with my old silverado. Replaced the master and the problem went away.
Old Oct 8, 2008 | 04:09 AM
Danny Wiseley's Avatar
Classic master cylinder symptom.
Old Oct 8, 2008 | 06:10 AM
crazy'boutOlds's Avatar
My 78 Delta did something similar after changing the rear wheel cylinders and bleeding the system. It ended up being the master cylinder.
Old Oct 8, 2008 | 09:25 AM
Felix, it's the Master Cylinder...
(yes, I'm dating myself)
Old Oct 8, 2008 | 09:41 AM
Good thing I have 4 extras from all my old deltas
Old Oct 8, 2008 | 06:08 PM
Get prices before you decide. I was AMAZED at how inexpensive a new one is. I believe the last time I needed a kit for the master cylinder on one of my Deltas, it was a little over the cost of a whole new master cylinder.
Old Oct 9, 2008 | 08:12 AM
Will do. Thanks again.
zodiacblueS
Brakes/Hydraulic Systems
44
Oct 12, 2014 03:22 PM
virtualwsp
Jun 13, 2012 02:00 PM
Del70
Jun 13, 2011 03:41 AM
eddieunderground
Nov 26, 2010 09:46 PM
w-30dreamin
May 10, 2010 09:49 AM
