68 front disk conversion
Old October 4th, 2017, 05:45 PM
servexcell's Avatar
Converting to front disk brakes. Using GM spindles new rotors and calipers aftermarket. New brake lines from Right Stuff. Existing was manual brakes.
Do we forget about the distribution block on frame or purchase a new one with porportionning valve. should we install new rear wheel cylindes what size?
Thanks Bruce
servexcell is offline
Old October 5th, 2017, 07:43 AM
Thanks Bruce
https://classicoldsmobile.com/forums...sk-brakes.html
joe_padavano is offline
Old October 5th, 2017, 08:05 AM
servexcell's Avatar
Very imformative.
As i understand we still need the porpotioning valve and distribution block. i think Right Stuff has a combo unit.
original was seperate. P.valve near brake booster. Were was dist. block located. On frame?
Do they still make parts
Old October 5th, 2017, 08:13 AM
Very imformative.
Contrary to popular belief, the 1967-70 cars did NOT use a proportioning valve. The metering valve that is mounted below the master cylinder on those cars is NOT a prop valve, it only delays the application of the front disk brakes slightly to allow time for the "slop" in the rear drum brakes to be taken up.
If the calipers and wheel cylinder are properly sized, a prop valve is not needed. Unfortunately, changes in weight distribution or other factors can disrupt this careful balance, which is why the 1971-up cars do use a prop valve, in addition to a metering valve. The combination valve in those applications incorporates the prop valve, metering valve, and the distribution block all in one housing. This is probably the better way to go, but requires more plumbing.
Old October 5th, 2017, 08:28 AM
servexcell's Avatar
What would i need to go from manual drums to power disk brakes if i want to keep it original.
Old October 5th, 2017, 08:35 AM
"Original" would have used the four piston calipers, not the newer single piston sliding calipers.
To be optically correct, you need the distribution block, metering valve, and correct master cylinder.
Old October 28th, 2017, 06:59 PM
Photoshop God
DewChugr's Avatar
Thanks Bruce
Don't throw away your old drum brake parts. We use those for C5/C6 swaps.
DewChugr is offline
Old October 29th, 2017, 05:09 AM
rob1960's Avatar
Hi Bruce, when I converted my '68 a couple of years ago I went the "optically correct" way under the hood, like Joe said using the dual-bail master & the metering valve. I kicked around buying the correct repop 4 piston calipers from Inline tube but I just couldn't justify the cost for a nice driver so I went with the single piston calipers. The '69 up style calipers, pads & hardware are so cheap & so easily available. Plus by keeping it "factory" under the hood all I had to buy was the 3 brake line set for pwr-disc brakes from Inline & bolt them in.
rob1960 is offline
Old August 4th, 2018, 11:17 AM
servexcell's Avatar
thanks Joe and Rob
should i get a booster from the parts vendors who get them from China or have an original rebuilt. Same question for MC
thanks Bruce
bry593
Brakes/Hydraulic Systems
April 4th, 2019 10:21 PM
VI Cutty
July 18th, 2017 08:53 AM
brown7373
March 26th, 2014 06:46 AM
Mike H.
April 15th, 2011 08:53 AM
1970442w30post
January 20th, 2011 05:06 PM
Quick Reply: 68 front disk conversion
