68 442 master cylinder question
Old May 20, 2020 | 09:00 AM
matt506's Avatar
Anyone know the cast number and stamped code on a master cylinder for a 68 442 with manual drum breaks ? W30 different?
Old May 20, 2020 | 01:39 PM
RocketDevo's Avatar
I do not know off the top of my head the casting numbers.
The Drum brake code for 1968 is "CT". Actually "CT" was predominately used on all 1968-72 Drum brake cars, including W30.
By the way the Disc brake code for 1968 is "DW".
Old May 20, 2020 | 04:08 PM
matt506's Avatar
Thanks I appreciate it. I believe mine is not original as I thought, because it is lacking bleeders. Now I need to find an original this helps much thanks.
Old May 20, 2020 | 04:40 PM
matt506's Avatar
Well at this point it’s off and the number cast in it is 5452410 makes it correct for manual drum breaks but has the front pad marked “ HU” or “HO” any idea what this is for? Matt
Old May 24, 2020 | 02:30 PM
RocketDevo's Avatar
Hey Matt, I do not know for sure what code "HU" and "HO" are for but they are not 1968-1972 Oldsmobile codes.
I gave rebuilt and core "CT" Drum brake Masters available though.
Thanks.
Old May 24, 2020 | 09:30 PM
matt506's Avatar
What ya asking for one?
Old May 25, 2020 | 03:23 PM
RocketDevo's Avatar
A core is $50.
The rebuilt ones, were rebuilt with stainless steel sleeves.
They were expensive, but will last the life of the car.
I would need $325 for a rebuilt one.
johnnyrockets
Brakes/Hydraulic Systems
Mar 12, 2019 06:10 AM
RocketDevo
Jan 12, 2018 03:21 PM
bobb
24
Feb 24, 2011 07:59 PM
JBrooks
Jan 11, 2011 08:09 PM
JBrooks
Dec 11, 2010 07:47 AM
