68 442 master cylinder question
Anyone know the cast number and stamped code on a master cylinder for a 68 442 with manual drum breaks ? W30 different?
I do not know off the top of my head the casting numbers.
The Drum brake code for 1968 is "CT". Actually "CT" was predominately used on all 1968-72 Drum brake cars, including W30.
By the way the Disc brake code for 1968 is "DW".
Well at this point it’s off and the number cast in it is 5452410 makes it correct for manual drum breaks but has the front pad marked “ HU” or “HO” any idea what this is for? Matt
