1970 Olds 98 LS Brake Rotor
Old Jan 9, 2023 | 11:25 AM
7098olds's Avatar
where in the world can I get a new rotor for my 1970 Olds 98 LS 455 ??
Old Jan 9, 2023 | 06:26 PM
No one makes new ones. You can adapt replacement rotors for a 2003-2006 Cadillac CTS with some machining. See this thread.
Old Jan 10, 2023 | 05:30 AM
7098olds's Avatar
This is fantastic news, I had read the post about the CTS rotors, but wasnut sure if it ever actually worked out. So all I have to do is have the center bored out on a lathe and redrill the stud holes? is there anything else that needs to be adapted for this to work? will the studs press into the rotors the same after they have been drilled out??
Old Jan 10, 2023 | 05:50 AM
Yes, center bore and redrilled lug holes are the only changes. The rest of the rotor dimensions are close enough to work just fine. The sliding calipers accommodate the negligible differences.
Old Jan 10, 2023 | 05:51 AM
7098olds's Avatar
Just being clear before I go disassembling the hub from the rotor, The wheel studs will still press in properly and I can use the factory Calipers?
Old Jan 10, 2023 | 05:55 AM
Yes. The holes in the rotor hat are new ones that you need to have machined, so if the machining is done correctly they studs press right in. The hat thickness is close enough to not matter. You might want to consider replacing the studs to avoid potential problems with worn or distorted splines. They are available from RockAuto.
Old Jan 10, 2023 | 06:02 AM
7098olds's Avatar
cant just drill the holes out??
Old Jan 10, 2023 | 06:04 AM
Look again
Old Jan 10, 2023 | 09:55 AM
7098olds's Avatar
Rotors are ordered, my buddy teaches metal shop and is gonna machine them out for us. Thank you so much
Old Jan 10, 2023 | 10:20 AM
7098olds's Avatar
so next question, which cadillac cts rotor is this? I called to order and they asked which suspension CTS has, I guess there are 2 different rotors for the 03 CTS
Old Jan 10, 2023 | 11:06 AM
Sorry, I thought the part number was in the link I posted above, but it isn't. They are the rotors for the base CTS brakes (FE1). I used Raybestos P/N 580120. There are several different versions available from Raybestos. I used the coated ones (580120FZN), but they are all the same dimensionally.
Old Jan 10, 2023 | 11:54 AM
7098olds's Avatar
got them on order now $150 canadian per side, better than scrapping the car cause it wont pass a safety inspection.
Old Jan 10, 2023 | 11:58 AM
RockAuto has them for $48 each. I don't know what that translates to delivered, however.
Old Mar 20, 2023 | 06:33 AM
7098olds's Avatar
Finally got one of the rotors back from the machine shop, 2nd one comes back this week. Went well, but my goodness wheel studs are not fun to install
Old Apr 17, 2023 | 10:31 AM
7098olds's Avatar
I will say that getting the new studs in and having them draw the hub tight to the rotor is posing a bit of stress for me. I have a small gap between the hub and rotor and I cant seem to get rid of.
Old Apr 17, 2023 | 11:32 AM
You need to use a press. Support the rotor from the wheel side and press the stud in from the backside of the hub.
Old Apr 17, 2023 | 12:19 PM
7098olds's Avatar
Ugh, I was hoping that would not be the answer,
Old Apr 28, 2023 | 07:56 AM
7098olds's Avatar
No press required, Used 3 washers and turned the nuts backwards ( tapered edge out) and we got it all put back together now. Thank goodness now for rear shocks and patch a small hole in the floor then off to get the safety done. Car should be on the road before he gets his license in June
hernameislargemarge
Brakes/Hydraulic Systems
Nov 17, 2016 05:42 AM
Ninety Eight Holiday
Aug 21, 2014 07:19 PM
liquidpower
Jan 9, 2014 07:55 AM
Sam Jelfs
Sep 28, 2013 01:26 PM
Kelly Peluso
Cars Wanted
Sep 26, 2012 03:30 PM
