4 piston rebuilder
Old Aug 28, 2022 | 09:06 AM
67OAI's Avatar
Old(s)GuysRule
4 piston rebuilder
Getting ready to have my 4 piston calipers rebuilt/sleeved ('67 442). SSBC used to be the only rebuilder years ago, now I find several others while searching for the service. Hoping that those of you who have used a rebuilder would provide some feedback on your satisfaction or dissatisfaction with that rebuilder. Thank you all.
Old Aug 28, 2022 | 09:13 AM
While I haven't used them for calipers, you might want to try White Post here in VA. They do nice work with master cylinders.
Old Aug 28, 2022 | 09:23 AM
briane's Avatar
Based on the recommendation from a close friend whose profession is performing concours restorations, about two years ago I had a master cylinder and some wheel cylinders stainless sleeved at Karps in California. I showed the finished product to my mechanical engineer/Ford fanatic friend at work and he thought they did an excellent job. At the time, turn-around was very good. Just one data point to consider.
Old Aug 28, 2022 | 09:42 AM
Sugar Bear's Avatar
Have used Karp's for brake items, very satisfied. Only heard good about White Post but haven't used them personally.
Good luck!!!
Old Aug 28, 2022 | 09:49 AM
Oldsmaniac's Avatar
I got some rebuilt ones a few years ago off Ebay, they were rebuilt by Carid?
Old Aug 29, 2022 | 07:28 AM
67OAI's Avatar
Old(s)GuysRule
Thank you all for the input; keep the comments coming.
Old Aug 29, 2022 | 08:10 AM
sysmg's Avatar
Let us know who you ultimately use. I have ones that I might need to have resleeved in the future.
Old Aug 29, 2022 | 08:49 AM
dc2x4drvr's Avatar
The best, their work goes the distance! ^^^^
Old Sep 14, 2022 | 09:02 AM
67OAI's Avatar
Old(s)GuysRule
I think that I shall go with rebuilt calipers from Ames (the Pontiac people) in New Hampshire. Any of you used them for anything?
Old Oct 26, 2022 | 06:51 AM
mpolds's Avatar
*** I have those Front Disc Brake Pads *** in N.O.S. Asbestos *** and with the non - availability of those
Disc Brake Rotors --- you would be foolish to utilize the new friction material on these new garbage brake pads,
land rip up those Rotors to smithereens.......
Always best to simply call me --- 516 - 485 - 1935 --- Craig......
Old Oct 26, 2022 | 08:12 PM
griffey57's Avatar
I used karps for my 57 olds. They did a great job rebuilding my power booster, I would recommend them or you could go with white post . I've heard a lot of great things about them, they would be my other choice
Old Oct 27, 2022 | 09:59 AM
briane's Avatar
I believe the distinction between Karps and Whitepost is Karps uses stainless steel sleeves while Whitepost are brass. I'm speculating that's why Whitepost doesn't provide a lifetime warranty when silicone DOT5 brake fluid is used. Other than the brake fluid consideration I don't know if there are any inherent advantages to one material over the other for this application.
Old Oct 27, 2022 | 10:07 AM
The silicone brake fluid has nothing to do with the metal in the sleeves. Brass is less reactive than stainless. The issue is reaction with the soft goods (seals).
Old Apr 28, 2023 | 06:34 PM
maddoctor's Avatar
Just my 2 cents on silicone brake fluid. A well known restoration shop just outside of Toronto will not use silicone brake fluid. When i did my restoration they recommended synthetic fluid. I told them I was already using that, for the last ten years actually and it is great. It does not attract moisture and after 10 years my brake fluid is as clear as the day I put it in. Just buy a quality brand.
VI Cutty
Apr 8, 2021 05:34 PM
60193W30
Dec 1, 2020 03:21 AM
Bigmikey65
Mar 26, 2020 07:48 AM
67442nut
Nov 19, 2015 06:49 AM
Jaybird
Mar 18, 2011 07:05 PM
