Piston/Cylinder Wall Clearance
Considering boring a '67 "E" block out .057" to accept a new set of 350 pistons.
This will be a stock rebuild.
What kind of piston/cylinder wall clearance should I ask for?
Off the top of his head, the machine shop guy was guessing 005"-007".
Seems high to me for a stock, non-racing rebuild.
In his defense, he DID say he would check what original specs called for.
These are what I'm planning to use:
http://www.ebay.com/itm/Speed-Pro-TR...5RuIqN&vxp=mtr
I got that.
That's why I'm asking here.
I was really hoping for good answers from experienced people
to keep from depending solely on the machine shop guy.
I guess I'll have to put up with the sarcasm to get answers.
I simply didn't know the answer.
I DID see 468's reply and I appreciated it,
although his answer came before I posted the exact piston I planned to use.
Ed that Ebay link is showing a .030 overbore piston, which would be 4.087 bore. They do have the same kit and a standard 4.057 bore, its on page 7 of their Ebay store. Maybe you have already seen this, but i would hate for you to get the wrong size.
Good catch. My mistake.
I bookmarked several options for pistons while I was searching for the best option.
I posted the wrong link.
This is the correct link to what I'm actually planning on using:
http://www.jegs.com/i/Sealed-Power/8...oductId=755706
Hi Ed, those are the pistons i was thinking about, until i clicked the first link you posted above. Falcon global has the same piston in a KIT as your first link above in standard bore. The pistons are coated and have moly rings included, for a little less than $100 more. The Jegs pistons do not come with rings and are not coated. I really dont know if the coating helps much or not. And maybe there are better or different rings you would prefer. I dont know seems like a pretty good deal to me. If you go to your first link above, Falconglobal on Ebay, then click on their Ebay store on the right, then on Oldsmobile, then page 6, you will see the coated piston in standard for Olds 350, 4.057 bore with moly rings, for $415.08 free shipping.
Or search the Ebay auction #190855113341
Wrist pins also included. The Jeg's deal didn't mention wrist pins.
Again, I'm not an engine builder,
but I know that that the type of build dictates the type of rings used.
This engine will basically be a stock build for a restoration.
I DO plan to use forged pistons, but I don't want to get into
complications with seating because I used the wrong rings.
I need to find out the best rings for my application.
Seems like I'd heard that the moly-chrome rings (I think) don't seat properly if not installed in a specific way.
I need more info on this subject.
I may put my foot in it occasionally, but, this car will mainly be a pretty day, cruise-in car.
Thanks again for paying attention.
