1970 Olds 98 LS Brake Rotor
This is fantastic news, I had read the post about the CTS rotors, but wasnut sure if it ever actually worked out. So all I have to do is have the center bored out on a lathe and redrill the stud holes? is there anything else that needs to be adapted for this to work? will the studs press into the rotors the same after they have been drilled out??
Yes. The holes in the rotor hat are new ones that you need to have machined, so if the machining is done correctly they studs press right in. The hat thickness is close enough to not matter. You might want to consider replacing the studs to avoid potential problems with worn or distorted splines. They are available from RockAuto.
Sorry, I thought the part number was in the link I posted above, but it isn't. They are the rotors for the base CTS brakes (FE1). I used Raybestos P/N 580120. There are several different versions available from Raybestos. I used the coated ones (580120FZN), but they are all the same dimensionally.
You need to use a press. Support the rotor from the wheel side and press the stud in from the backside of the hub.
No press required, Used 3 washers and turned the nuts backwards ( tapered edge out) and we got it all put back together now. Thank goodness now for rear shocks and patch a small hole in the floor then off to get the safety done. Car should be on the road before he gets his license in June
