1956 Oldsmobile EXTREMELY Sensitive Brakes
Old Jul 10, 2024 | 03:50 PM
Thenson's Avatar
When barely touching the brake pedal brakes will lock up. It's still drum brakes all around.
Old Jul 11, 2024 | 04:30 AM
Have you replaced the brake hoses recently? Sounds like they might have failed. When brake hoses age they're known to fray internally and act as a pressure check valve when activating the brakes. If you remove your drums to inspect for leaks and one of them is difficult to remove this is another sign.
Old Jul 11, 2024 | 04:33 AM
66_Jetstar's Avatar
How often do you drive it? Drums are notorious for being touchy with rust build up. We had an old tow truck that would lock up instantly for the first couple of stops. Once the rust wore off they worked as they should.
Old Jul 11, 2024 | 09:25 AM
Thenson's Avatar
The wheels rotate freely. Just all lock up when barely applying the brake.
Old Jul 11, 2024 | 12:38 PM
VC455's Avatar
Barely Registered
We're not saying the drums are rusted to the shoes, preventing motion.
We are saying that there may be a coating of surface rust on the drum--not enough to interfere with free rotation.
The friction coefficient of that rust is FAR greater than that of bare iron. So, when you apply the brakes they GRAB.
With brake applications, that surface rust will wear away and you will be back to the pedal feel you are accustomed to.
That's what's being proposed. Try it. And we hope it works out that way for you.
Old Jul 11, 2024 | 12:44 PM
Oldsmaniac's Avatar
Not to be contrary maybe you are just putting too much pressure on the pedal. My 1st Olds a 66 Delta had touchy brakes, not necessarily "locking up" but touchy. I got used to them and no problem. My dad would borrow the car at times and first few stops had everyone lurching forward...
Old Jul 11, 2024 | 02:30 PM
Ensure the brake fluid reservoir is not overfilled. Brake fluid heats up as it heats up, it expands - as the fluid expands it needs a void above the fluid to expand. If there isn't a void (air) over the brake fluid in the brake fluid reservoir (e.g. over filled condition), pressure will build in the system and begin to prematurely apply this pressure to the brakes. If that could be the case, remove (turkey baster) some brake fluid to provide some head space in the reservoir.
Old Jul 11, 2024 | 02:36 PM
66_Jetstar's Avatar
If your storage is damp/musty then this will happen every time you get in the car. Drive it, ride the brake briefly and try again. I'd bet a cold beer it'll work better.
Old Jul 11, 2024 | 04:03 PM
Thenson's Avatar
Thank you everyone for your input! However, the inside of the drums are not rusty.
Just so everyone is on the same page, we are a shop not a DIY. You can visit our website at www.britishsportscars.com. Of course even professionals can overlook things, but I thought this was important to add some context.
Old Jul 11, 2024 | 05:05 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
See the related thread below. Keep scrolling down.
Old Jul 12, 2024 | 04:54 AM
Here's a link to the thread mentioned above:
https://classicoldsmobile.com/forums...abbing-135466/
The continual scroll feature of our site can be a PITA!
Old Jul 12, 2024 | 05:03 AM
Disable it.
Old Jul 12, 2024 | 07:46 AM
Charlie Jones's Avatar
Phantom Phixer
I think I remember encountering several "touchy" power brakes on Oldsmobiles and Pontiacs.
Many years ago.
The solution usually was a rebuilt power brake unit.
Old Jul 12, 2024 | 07:48 AM
Yeah, I don't mind it too much and just posted the link for those of us that are nearly computer illiterate, @Oldsguy I rarely make posts in the wrong thread.
Sorry, thread hijacked.
Old Jul 12, 2024 | 08:53 AM
Oldsguy's Avatar
Past Administrator
huh????
Old Jul 12, 2024 | 09:47 AM
stan 65 cutlass's Avatar
shoes on upsidedown ?
Old Jul 12, 2024 | 01:24 PM
coldwar's Avatar
If your 56 has power brakes, the booster is failing or is assembled incorrectly. Check by disconnecting and plugging the vacuum supply to the booster, then CAREFULLY drive and check braking action. Will require a lot more pedal effort but should still stop.
ripper27
May 23, 2019 06:36 PM
brown7373
Brakes/Hydraulic Systems
21
Jun 13, 2017 12:00 PM
help442onguam
Nov 13, 2015 09:20 AM
1956olds88post
Aug 22, 2013 06:33 PM
edwardthebear
Oct 18, 2010 07:49 PM
