Rear Brake Cylinders and Shoes
Old Jul 12, 2024 | 05:02 PM
crashman's Avatar
Greetings group, I'm looking for some guidance and information. I have a 1957 Olds 3rd member in my 1955 Chevy. It has a blown wheel cylinder and the shoes are pretty soaked with brake fluid. I don't know what model the rear is out of. I guess the question is, are all the rear cylinders the same? What about brake shoes?? Any help will be greatly appreciated. The only thing that I'm sure about is the it is 4.10 posi.
Old Jul 12, 2024 | 08:32 PM
Post pictures of the rearend. Center section, yoke, rear cover, to start. Don’t zoom in excessively. Folks will be able to ID what you have with enough pictures.
Old Jul 12, 2024 | 09:12 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I am about +90% sure all the rear ends in 57 were the same. That is a tough rear end.
Old Jul 12, 2024 | 09:56 PM
Charlie Jones's Avatar
Phantom Phixer
All 57 & 58 Olds used the same rear brake cylinders. Factory # 5456504 (rh) & 5456505(lh).
Brake shoe coverage is even more broad.
1954 thru 1963 all models except F-85. Factory # 5461645
Old Jul 15, 2024 | 02:56 PM
crashman's Avatar
Greetings group, thanks for your information and reply's. I was able to order some new cylinders and shoes. I tried to post up some pictures, but I keep getting error messages. I'll get it figured out and post em up.
Old Jul 15, 2024 | 06:32 PM
tnswt's Avatar
'70 4-Speed W Machine
If the wheel cylinder bores are not pitted, they are a simple rebuild rather than buying new.
Old Jul 16, 2024 | 01:17 PM
crashman's Avatar
True, but they are cheap enough just to replace them
Old Jul 16, 2024 | 03:45 PM
redoldsman's Avatar
Except the replacements are probably going to come from China.
Old Jul 16, 2024 | 07:50 PM
But that does not automatically make them bad. Where do you think the rebuild kits come from?
Old Jul 16, 2024 | 09:19 PM
redoldsman's Avatar
I didn't say it made them bad but the odds of it are more likely. Most brake parts are made in China.
Benjamin Deffendall
Brakes/Hydraulic Systems
Oct 14, 2023 02:28 PM
russell-t
Dec 12, 2022 12:16 PM
69442murph
Dec 6, 2021 02:43 PM
Reese Neis
Sep 20, 2020 09:41 PM
Nate Lintz
Mar 23, 2016 04:40 PM
