Rear wheel seal?
Rear wheel seal?
Where can I find the rear window glass seal or weather stripping? It's for my 71 supreme I've searched with no real leads. For all I know I'm not calling it by its right name.
There is no "fitted strip" or molded gasket. The glass is simply glued to the pinchweld flange using the butyl tape shown above. That's how the cars were built at the factory.
By the way, if you are doing this to fix a leak, you most likely have the dreaded and all-too-common pinchweld rust.
You slide it between the glass and the trim, then run along the trim until you hit one of the clips. Rock the tool to pop the trim loose from the clip. (This photo is a different style tool, but the use is the same)
