1984 Olds 98
Old November 16th, 2021, 07:45 AM
razor07's Avatar
1984 Olds 98
Hi, I have decided to restore my 1984 Olds 98 4 door sedan. I want to replace my vinyl roof and need any and all information to do so as I understand the rear window is tricky. Also where do I find the information on the parts codes ID.
razor07
razor07 is offline
Old November 16th, 2021, 09:44 AM
To start you will want to get a Factory Service Manual and Chassis Service Manual for your Olds. The CSM has directions on how to properly remove the vinyl top.
Have you done bodywork before?
Olds64 is online now
Old November 16th, 2021, 09:58 AM
razor07's Avatar
Yes I have body work before, just need instructions on proper steps when removing roof. Where would you recommend to get vinyl replacement kit from?
razor07 is offline
Old November 16th, 2021, 11:22 AM
I'm not sure where to get a vinyl replacement kit. I bought trim for my 71 98 to install a vinyl top but I've never installed it. In fact, if I ever installed a vinyl top I would leave it to the experts. Knowing my luck I would get the seam down the center of the vinyl crooked.
hubie
Ninety-Eight
April 19th, 2007 10:18 AM
hubie
Ninety-Eight
April 17th, 2007 06:27 PM
Quick Reply: 1984 Olds 98
