Filler or seam sealer here?
Old Apr 25, 2021 | 01:51 PM
ajr2820's Avatar
See photo. This is the area where the A pillar and dash join. After applying seam sealer, I am wondering if I need to use some short strand here?
Old Apr 25, 2021 | 03:24 PM
68442's Avatar
Seam sealer was OEM in that location. If you are asking about factory application
Old Apr 26, 2021 | 03:24 AM
tommieb's Avatar
Will this show? And is it a welded/spot welded seam.
Old Apr 26, 2021 | 05:31 AM
68442's Avatar
It is a welded seam. After paint, A combination of the dash pad and pillar cover and from the outside the lower windshield trim will cover it
Old Apr 26, 2021 | 09:44 AM
bccan's Avatar
Seam sealer in that location, looks good to go.
Old Apr 27, 2021 | 03:27 AM
tommieb's Avatar
Yep as said good to go
Old Apr 27, 2021 | 05:53 AM
chopolds's Avatar
Not sure if you want to put filler over the seam sealer (a BIG no no), or fill in the gap? Either one is a no. You don't put any filler over something flexible like seam sealer, and you don't use it to fill gaps. The seam sealer by itself will work fine. Seams like that tend to move a bit , so something flexible is best.
Old May 1, 2021 | 07:02 AM
ajr2820's Avatar
Wasn't going to cover it with filler. After seam sealing it, I wasn't sure if there was filler there originally. If it needed filler, I was going to remove the sealer. Just could not recall what was originally there.
FStanley
May 26, 2023 08:07 AM
cdrod
Jul 29, 2019 04:57 PM
sjay1989
Mar 2, 2019 03:38 PM
blunce
Body work
16
Nov 2, 2014 12:02 PM
