Vinyl Halo Top - Small Bubble
Old Apr 30, 2021 | 04:30 PM
tgilligan's Avatar
Hi,
I noticed a small dollar coin sized bubble in my vinyl on my ‘70 Supreme hardtop. When pressed there is no outwardly visible signs of rust but who knows. It’s solid underneath the bubble and no play in the metal. It’s on the drivers side almost centered of the side roof panel, about 3-4 inches above where the ‘CS’ emblem is. Assuming rust isn’t the issue, is there a good fix for this? I’ve read everything from remove it, to heat it, glue in a syringe,etc. Has anyone else successfully addressed this?
Old Apr 30, 2021 | 08:09 PM
66SportCoupe's Avatar
The roof seal has lost its bond due to surface rust. It needs to be looked at.
Old May 1, 2021 | 04:17 AM
tommieb's Avatar
I also think rust is starting under the top.I see this all the time.I know not you want to hear.
Old May 1, 2021 | 06:12 PM
tgilligan's Avatar
Well that brings up part 2 question...wonder what’s involved in replacing the vinyl top and using something like POR-15 prior to putting the new top.
Old May 1, 2021 | 08:04 PM
Nothing other than a few hundred dollars won't cure.
Old May 2, 2021 | 03:49 AM
tommieb's Avatar
Please no Junk 15 You will have to remove the vinyl top and see what you have from there. Let us know from there. Could be easy as sand ,epoxy primer and Paint
deathvader
Jan 22, 2021 05:35 AM
Billyaxe
Body work
18
Aug 11, 2018 04:50 PM
midnightleadfoot
Mar 27, 2018 08:57 AM
Rocket71
Body work
Nov 25, 2008 03:48 PM
cgjon
Jun 26, 2006 06:19 PM
