Vinyl top
Vinyl top
Im wanting to know if I can save my vinyl top. The top is in excellent condition but I seem to have some rust in some areas by the back window. My question is could I reuse the same vinyl top if I'm able to take it off without harming it?
Maybe, it's hard to say until you peel it back. Often times small pieces of rust bubbles stick to the vinyl glue. Then when you glue it back, there are bumps. Even if it comes off without bumps, there will be tiny rusted particles stuck on it. You can't clean them off. A black top, if you're tight for $ and goes well it could last a while with a used top...maybe!
I am currently building a 71 clone daily driver. The cheapest top I could find was this one for $150.00 :
https://www.oldsparts.com/product/vinyl-top-black/
The only problem is that it was not the right shape. Other tops I have put on have seams for the A-pillars and the rough outline of the C-pillars. This was just one big rectangle with two pressed seams. It was not long enough to go to the front and rear of the pillars. I ended up making my own seams at the top of the A-pillars and using some of the excess material from the sides. As I said it will be a daily driver so it is good enough for me.
Here is a shot of the A-pillar seam
That sure is a nice rear quarter panel. Mine both need some work. Wonder what the process of just deleting the vinyl altogether would be. Guess only time will tell. Gonna pull the motor again and try to figure out some weird noise that keeps rattling. And actually figure out what all parts were put in the motor.
As to shaving the top, Other than rust, the studs for the quarter moldings will probably be your biggest problem. The quarters can warp a fair bit from where they were spot welded on at the factory. Also, the factory did not finish off the leaded seams in the roof as well on vinyl top cars so that may take some also.
Yeah thats an ideal. I really like the look of the vinyl on this car. I wish someone wouldn't have left it outside or something. Or would have fixed the rust before putting the vinyl top back on.
Be aware that there may have been more than one vinyl top available on your car. I bought trim to put a vinyl top on my 98 and found that there was a factory vinyl top and dealer vinyl top installed in 71.
FWIW, I don't think it would be feasible to reuse a vinyl top. Once it's removed the glue left on the bottom would destroy the vinyl and the only way to prep the car again for a vinyl top would be to remove he whole thing.
midnightleadfoot
March 27th, 2018 08:57 AM
