Window Felt
Old Jun 17, 2020 | 05:55 PM
miller6323's Avatar
Window Felt
Hi everyone,
I have a 1980 cutlass supreme 2 door t top car that I'm bringing back to life. All of the other rubber is fine but the window felt has gotten stiff and brittle. I can't seem to find any for an 80. Lots for an 81 and up but I'm not sure what is compatible. If anyone knows what other vehicles will cross over or up to what year will work id appreciate it.
Old Jun 18, 2020 | 02:38 PM
Tedd Thompson's Avatar
Try your local auto glass shop they buy felt by the stick and cut it for what ever their needs are. Well anyway that is what I did when I had a side window replaced, no biggie that it was for a 65 year old car... Tedd
Old Jun 18, 2020 | 04:21 PM
69HO43's Avatar
Found you some genuine GM ones. Ain't cheap, but they don't grow on trees either. The application is wrong in the writeup, but are the right numbers for a 1980. Should fit 78-80 Olds A47 WITHOUT wide molding. 81-88 used a different one.
https://www.ebay.com/itm/1978-1981-O...QAAOSwkr5ZiwNx
P/N 20152195 is the p/n for the inner felts on the inner door panels. Fits either side.
Not sure if they make these aftermarket.
Old Jun 29, 2022 | 08:01 PM
70RocketSteve's Avatar
I have a set listed on eBay $149.95 if you are still looking
Old Jun 29, 2022 | 08:53 PM
miller6323's Avatar
I found a set on Mikesmontes.com that worked. They were for a Monte Carlo but fit like a glove. Thanks.
Old Jun 30, 2022 | 11:32 AM
Sounds good!
stevestringer
Apr 19, 2020 05:00 PM
Rosco920
May 17, 2019 06:33 AM
PM70
Dec 7, 2016 08:47 AM
Four Four Tony
Apr 12, 2010 08:26 AM
fizzy55
Sep 30, 2009 09:18 PM
