Silver and Black
Old Jun 24, 2011 | 11:53 AM
mhood's Avatar
Silver and Black
Anyone know a good way to paint these? I don't see how to mask them.
Old Jun 24, 2011 | 12:50 PM
ddx77's Avatar
I'm getting ready to do mine and plan on using pin stripe tape for the fine edges.
I believe someone on this forum had suggested it in the past so I can't say it was my idea.
Old Jun 24, 2011 | 08:38 PM
70Post's Avatar
If you go to an auto paint supply store they should have a good quality 3M blue vinyl tape in a narrow width. Or you can even use the real narrow regular 3M masking tape from the same source (the stuff that's the typical light brown in color).
As Drew already suggested, the pinstripe tape should also be fine. In fact, it may be a bit thinner and easier to make curves with. Also easy with regard to getting it....any auto parts store probably has it.
Old Jun 24, 2011 | 09:31 PM
oldsrocket88's Avatar
I've always used clean grease and applied with my finger (slowly) on the sections that I want unpainted and just spray the whole piece. Let it dry very well (a good day or two) and then just take a clean rag and wipe.
Old Jun 24, 2011 | 10:14 PM
geowindow6768's Avatar
I sprayed my housings with satin black, after cleaning them up, and then took a rag with paint thinner and wiped off the overspray and they turned out amazingly nice plus it was quick.
Old Jun 25, 2011 | 05:28 AM
scott_442's Avatar
Paint the bezels and use a buffing wheel to remove the paint on the edges. While you're at it, consider sanding the edges to remove the anodized finish and polish them to a chrome like finish. I started with 150 grit and finished with 2000. Takes a little time but the results are worth it.
Old Jun 25, 2011 | 05:35 AM
scott_442's Avatar
Polished bezel.
Old Jun 25, 2011 | 05:46 AM
scott_442's Avatar
btw, it looks like yours are mounted incorrectly. They should be parallel to the bumper...just flip them around and you should see the difference. I've seen this same thing on show cars
Old Jun 25, 2011 | 06:06 AM
69442C's Avatar
It appears to me that your bezel and that of mhood are both installed incorrectly. The small notches in the bezel to get to the headlight adjusting screws are not in the correct location. There is an adjustment screw at the top and on one side yet both photos show a notch for a screw at the bottom, where there is no adjustment screw. It appears they are upside down and possibly on the wrong side.
Old Jun 25, 2011 | 06:19 AM
scott_442's Avatar
Good Point! And thanks for sharing! Never knew that about the slots for the adjusting screws. That's why I love this site. People with knowledge willing to share in an open forum!
Old Jul 5, 2011 | 11:58 AM
mhood's Avatar
I took off the bezels and decided to clean them up before painting with some Goof Off I had lying around. I was amazed how shiny they looked underneath the paint so I spent a couple hours trying to get all the paint off. I like the look, I know its not correct for the 72 but it seems to make the front end pop. Thoughts?
Did Olds really just paint the chrome over for 72? Weren't the 71's like this?
Thanks for the advice, I think I got them mounted properly.
I didn't like the way the paint looked on the medallion so I am going to try again.
Old Jul 5, 2011 | 12:37 PM
mhood's Avatar
here is the picture of the chrome
4speed455
May 29, 2017 06:38 AM
onofre442
Sep 10, 2013 02:24 AM
jonesolds442
Feb 3, 2013 10:00 PM
bdub217
Aug 23, 2012 11:03 PM
1987442
May 9, 2007 10:48 AM
