Quarter window issues
My left rear quarter window will not roll up on its own without me having to grab the window and help it up as I turn the window crank.
Is this a regulator issue or are the rollers shot? I'm thinking rollers.
It's a 68 442 convertible...
In any case, if the window needs help going up because it is cocking as you try to raise it, chances are it is a roller issue. In any case, the back seat needs to come out so you can remove the interior trim and investigate (or even to lube the tracks).
I try not to use petroleum-based greases on plastic parts (ie, the window rollers) as this eventually deteriorates the plastic. I prefer silicone grease.
of the silicone spray grease.
I lubricated all my tracks and rollers with silicone spray and it as improved things but i noticed that none of the nylon rollers actually turn at all. Is this normal or are they all in a stuck position? I wanted to ask before i start taking everything apart.
olds70supreme
Oct 16, 2014 05:04 PM
