Quarter window issues
Old Aug 5, 2016 | 06:21 PM
Stevec's Avatar
My left rear quarter window will not roll up on its own without me having to grab the window and help it up as I turn the window crank.
Is this a regulator issue or are the rollers shot? I'm thinking rollers.
It's a 68 442 convertible...
Old Aug 5, 2016 | 06:24 PM
tru-blue 442's Avatar
Old School Olds
You may try a shot or 2 lithium grease spray. I get mine at Wally world.
Works well for door hinges too.
Old Aug 6, 2016 | 06:32 AM
I try not to use petroleum-based greases on plastic parts (ie, the window rollers) as this eventually deteriorates the plastic. I prefer silicone grease.
In any case, if the window needs help going up because it is cocking as you try to raise it, chances are it is a roller issue. In any case, the back seat needs to come out so you can remove the interior trim and investigate (or even to lube the tracks).
Old Aug 6, 2016 | 06:58 AM
Stevec's Avatar
Joe, how difficult is it to replace the rollers once the glass is out of the car? How many rollers do I need to buy? Fusik has them for about $12 each.
Old Aug 6, 2016 | 07:53 AM
Since your is a convertible, I would pop the side panels and inspect before ordering any parts. It may be just some adjustment and/or rust or corrosion issues.
Old Aug 6, 2016 | 08:30 AM
Old School Olds
Thanks for the info Joe. Had to go to Wally's this morn and got me a can
of the silicone spray grease.
Old Apr 7, 2019 | 02:14 PM
W-27's Avatar
I lubricated all my tracks and rollers with silicone spray and it as improved things but i noticed that none of the nylon rollers actually turn at all. Is this normal or are they all in a stuck position? I wanted to ask before i start taking everything apart.
Don Roberto
Mar 11, 2017 02:29 PM
olds70supreme
Oct 16, 2014 05:04 PM
ctrain22
Nov 2, 2009 06:12 PM
1973olds98
Ninety-Eight
Aug 4, 2009 01:43 PM
ctrain22
May 30, 2009 08:45 PM
