Need Help With Trim - Going From Landau Half Vinyl Top to No Vinyl Top
Old Apr 7, 2024 | 08:32 PM
mapearso's Avatar
I am restoring a 1978 Delta 88 Holiday 88 that came from the factory with a Landau / Half Vinyl Top.
The Landau half vinyl top is trashed. I have removed the top and I am NOT planning to reinstall it. Instead, I am going to make it a ‘slick top’ or ‘bald head’ - meaning, no vinyl top, I’m just going to paint it.
Here’s the problem - the back window does not have any clips to hold the aluminum trim - because the half vinyl Landau top didn’t have any aluminum trim around the back window… only below the rear window and across / around the top
So… how can I solve this problem? Non-vinyl top and full vinyl top cars had metal clips to hold the aluminum trim around the rear window.
Are there aftermarket clips I can use? Would I have to weld them in place???
Does anyone have any suggestions? I’m hoping someone here removed one of these half tops from a Cutlass or Delta 88 and figured out how to hold the rear window trim in place …
Pics are worth 1,000 words so please see below …
Landau / Half Vinyl Top Examples … No aluminum trim around the back window
No clips to hold trim …
Slicktop and full vinyl top cars with trim around the back window …
They have clips like this ….
Any advice, help, suggestions are much appreciated !!!
Old Apr 8, 2024 | 05:48 AM
chopolds's Avatar
You can buy clips from any body shop supply house, though it is easier if you bring an example of one, to match it. Still, even pics might help. You can attach them with one of the following: studs, that you put on with a dent pulling stud gun, or tiny screws made for this purpose, or pop rivets (least desirable)
Old Apr 8, 2024 | 08:36 AM
TRFREE's Avatar
The set-up on your white Holiday should have the correct moldings and clips. If the clips are trashed, you should be able to match something up. I would even try a local glass installer.
Old May 25, 2024 | 12:52 PM
Bernhard's Avatar
They make molding stud trim screws.
Liking the vinyl roof delete.
This is just a sample not endorsing this brand!
Old May 25, 2024 | 02:42 PM
mapearso's Avatar
Thanks this is very helpful!
Old May 27, 2024 | 08:01 PM
tkcutlass's Avatar
These guys have a number of different studs and clips
https://www.rustreplace.com/home/glass-setting-supplies
Old Jun 6, 2024 | 04:27 PM
mapearso's Avatar
Thanks -- this is very helpful!
Mar 26, 2023 12:32 PM
Kiwicutlass
Body work
Dec 30, 2022 01:01 PM
mwbailey
Nov 18, 2022 07:54 PM
72 Post
Body work
Aug 23, 2022 06:52 PM
footbrake
Body work
Mar 14, 2012 04:57 PM
