Hood to Cowl weatherstripping
Old Jul 30, 2013 | 12:40 PM
wcourt3010's Avatar
Hi, can anyone tell me how that length of rubber hood to cowl weatherstripping is installed, its available from Steele and on summit from various manufacturers. I can't see where it would clip in if it has those little clips or does is it just afixed with weatherstripping glue?
just trying to tighten things up on my hood with bumpers etc. and keep seeing this weatherstripping.
Old Jul 30, 2013 | 01:26 PM
midrange's Avatar
Shaking out the cobwebs..
It goes in with clips that attach near the front of the screen that covers the cowl. I don't know the length right now.
Just beware that if you get one, make sure it is soft enough to allow your hood to close.
I replaced my 'barely there' old one with a new one. When I closed my hood, the rear edge of the hood, wouldn't go down. I tried adjusting the hinges to no avail. I spent half an hour trying to get it to close properly. Finally I had had enough and just removed the new seal. I'll have to find something a lot less firm to put in.
Old Jul 30, 2013 | 01:38 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Go to Fusick or Year One. They list dense and soft versions. Of course the soft one is more. No idea why there is two versions for 68-72s? Call the tech line for further assistance.
Old Jul 30, 2013 | 02:05 PM
455man's Avatar
The weatherstripping folds over the clips so they are not visible. Mine too holds the rear edge up even though it seemed soft. Parts place I think is where I got mine.
Old Jul 30, 2013 | 02:12 PM
brown7373's Avatar
Year One and maybe others sell both a soft version and a more dense version. Year One is the same price for either. I bought the dense and had the same problem. The back of the hood won't close and looks terrible. I don't understand why they sell the dense version, because it doesn't work.
Old Jul 30, 2013 | 02:18 PM
don71's Avatar
same but different
Its been awhile since I done mine. I don't remember any clips...so I'm glad someone brought that up. I do remember having the hood higher than the fenders for quite awhile. Back then it was A&M softseal? products I used.
Maybe once or twice the seal would stick to the hood also(fresh paint). Sounds like we got some more options now, thank goodness.
Old Jul 30, 2013 | 07:05 PM
Lady72nRob71's Avatar
I had to slit the slots for the clips in the seam provided on the seal, which faces the windshield. Cut an X where the clip stud goes. I marked the holes on the car then cut them on the ground and installed the clips. It went on easily.
Get the foam one and not the hard rubber, unless you like the rear of the hood 1/2" above the fenders. Forever...
Old Jul 31, 2013 | 11:10 AM
ROCKET VAPOR's Avatar
Lance
Metro brand cowl seal mfg. part number CH 5 is the correct style and density.
Here is a link to one for reference, but shop around for best price.
http://www.ebay.com/itm/New-Metro-Mo...8524d0&vxp=mtr
Soffseal makes one of the correct styles of cowl seal retaining clips mfg. part number 5075. This style is not only correct, but is very thin after it is compressed.
Again, shop around for best price.
http://www.ebay.com/itm/NEW-HOOD-SEA...ced4c5&vxp=mtr
With the opening in the seal facing toward the rear of the car, start in the middle of the seal using a scratch awl to punchure the holes in the seal for the retaining clips as you work your way out to the edges taking up the slack as you go.
Hope this helps
Old Aug 5, 2013 | 03:02 PM
jfb's Avatar
jfb
I routed mine in a alternative manner as seen on a 1971 cutlass s across the channel straight . I also cut down the center rubber support now my fiberglass hood is sealed and is flat.
Old Aug 6, 2013 | 08:56 AM
455man's Avatar
jfb can you post a pic of what you did?
Old Aug 6, 2013 | 12:53 PM
jfb's Avatar
jfb
I do not keep pictures before or after my work it was meant to enjoy and not to show off performance work does that by it self period sorry. I cut down in small amounts the center bumper with 80 grit carefully on a da after i put the weatherstripping in the channel along the front by the engine rear, channel on the firewall . I would if you find this channel along the front of the firewall behind the distributor on the top.
Old Aug 14, 2013 | 01:23 PM
wcourt3010's Avatar
so there are plastic clips holding that screen in, do those come out and the clips for the weather sealing go in their place? i can see no other holes where it would attach.
Old Aug 14, 2013 | 02:37 PM
midrange's Avatar
The plastic clips in the front of the screen are the clips that hold the weather strip in. I left them in to help hold down the screen when I removed the stiff strip.
Old Aug 15, 2013 | 06:42 AM
wcourt3010's Avatar
that's perfect, thanks for the pic.
pfergy600
Jul 29, 2014 06:09 PM
Sampson
Jul 18, 2014 04:36 PM
DAN76
Oct 14, 2008 06:22 AM
Omicron
Jul 5, 2008 09:03 PM
Doug69Cutlass
Apr 15, 2008 04:50 PM
