Get the lead out?
Get the lead out?
I had a hood, doors, and fenders professionally media blasted
They were what appeared to be perfect...but a couple of pinholes reared their heads and now I have otherwise beautiful pcs with a couple tiny holes...seems that cutting out and welding in sheet metal is more damaging than helpful...what should I do? Lead? Fiberglass? Other?
Thanks for any and all advice.
Cut the metal out. pin hole are usually signs of a bigger problem test with an awl around the hole until you cannot push is thru that's where the good metal starts. should not take much welding to fix
