Get the lead out?
Old Nov 9, 2010 | 01:04 PM
Olds Dad's Avatar
Collector of Stray 55's
Get the lead out?
I had a hood, doors, and fenders professionally media blasted
They were what appeared to be perfect...but a couple of pinholes reared their heads and now I have otherwise beautiful pcs with a couple tiny holes...seems that cutting out and welding in sheet metal is more damaging than helpful...what should I do? Lead? Fiberglass? Other?
Thanks for any and all advice.
Old Nov 9, 2010 | 02:04 PM
citcapp's Avatar
Cut the metal out. pin hole are usually signs of a bigger problem test with an awl around the hole until you cannot push is thru that's where the good metal starts. should not take much welding to fix
Old Nov 9, 2010 | 02:43 PM
gearheads78's Avatar
car guy
Only way to fix it right is to cut out bad and weld in new metal.
Old Nov 10, 2010 | 05:40 AM
Olds Dad's Avatar
I guess I already knew the answer ....thanks for the help _ and richard-i had a 71 green& white v/c that I also called " the booger" ...funny. I also like your flag.
Allan R
Jul 2, 2011 10:01 PM
DennisG.
Jun 29, 2008 05:17 PM
Redog
Apr 9, 2008 12:24 PM
American Lead
Jan 5, 2008 08:39 AM
oldssragtop
Jan 10, 2007 11:54 PM
