Driver Side Door Will Not Open
Old Sep 13, 2023 | 10:18 AM
MNtoTX1985's Avatar
Hello all,
I just purchased by 1968 Cutlass "S" yesterday and last night, after showing off to the neighbors, I locked it up and went to bed. This morning, even though the door is unlocked, the handle from the inside and outside will not open the door. Please advise on how to open this door as climbing through the passenger side kind of stinks.
Thanks,
Old Sep 13, 2023 | 11:14 AM
Jake707's Avatar
To confirm, both the inside are outside handles dont work and youre sure its unlocking the cylinder? If so there must be a break in the linkage inside the door and the only way I would think to open it now is by removing the inner door panel. This could be a real PIA with the door closed and maybe one of the more experienced here will have a better solution but you have to engage that latch assembly somehow.
Old Sep 13, 2023 | 11:20 AM
leftlaneonly's Avatar
Can you roll window down to look inside and see what's still moving
Old Sep 13, 2023 | 12:17 PM
VI Cutty's Avatar
Assuming you can get in from the passenger side, pull up the interior handle fairly hard and simultaneously shoulder check the door frame. That "might" pop it open. Works on mine, but my outer handle works fine.
The latch mechanism inside the door can get sticky preventing the latch from releasing properly.
John96OldsLSS
May 24, 2022 08:45 AM
tkcutlass
Mar 2, 2020 07:32 PM
Cincinnati Rick
May 17, 2017 03:52 AM
UCF72Cutlass
May 23, 2008 11:28 AM
dub60478
Aurora
Oct 4, 2006 04:56 AM
