Do they make a patch panel for this?
Old Sep 13, 2023 | 11:56 AM
Michael_'s Avatar
1972 Oldsmobile Cutlass Supreme.
I need to replace the trunk seal but that's no big deal since i found it here on rockauto for cheap: https://www.rockauto.com/en/moreinfo...1221691&pt=793
Problem is that below the gasket the metal is rusted away in an area.
The following picture is for illustration purposes regarding where the rust is located at. It's NOT my car.
I checked rockauto.com, opgi.com and yearone.com but did not find a patch panel.
Do they make one and if so where can i buy it?
Old Sep 13, 2023 | 12:13 PM
redoldsman's Avatar
Proud Viet Nam Veteran
To my knowledge nobody makes that. It should be pretty easy to find some used sheet metal. If that is the only area it would not matter what body style it came from since it short and straight. It could come from several year models.
Old Sep 13, 2023 | 07:36 PM
Funkwagon455's Avatar
Oldspackrat….😉
Old Sep 14, 2023 | 06:21 AM
Andy's Avatar
At one time a company called Beldenspeed.com sold reproduced trunk channel..
Old Sep 14, 2023 | 08:45 AM
tkcutlass's Avatar
https://www.rustreplace.com/home/1964-1972-cutlass442
has the channels
Old Sep 14, 2023 | 01:48 PM
Rallye469's Avatar
It would help to see a picture of yours...but-
1. I imagine any straight line in any place around your trunk could be used to fix that area.
2. If it's JUST the bottom of the channel, weld in a strip of sheet metal. No one will see it.
Old Sep 16, 2023 | 09:23 AM
Michael_'s Avatar
Originally Posted by tkcutlass
I have not found the needed panel on these websites however i talked with my body & paint guy and he thinks he will be able to fix it without a patch panel. So problem most likely solved.
Vintage Chief
Body work
19
Apr 25, 2023 03:51 AM
Mauch712
Jan 24, 2020 05:52 AM
Rustbucket2
Body work
Sep 26, 2019 10:26 PM
Eddie Hansen
Body work
26
Aug 13, 2012 08:41 AM
Ranzan
Mar 27, 2010 04:20 PM
