Door hinge roller
Old Jan 29, 2012 | 11:28 AM
69postman's Avatar
Door hinge roller
How does the pin come off for the detent roller? The roller is off already because it was worn out. Now with new bushing in roller, it does not go over head of pin. Does the pin come out somehow? My manuals don't show hinges. Thanks Brian
Old Jan 29, 2012 | 04:26 PM
Lady72nRob71's Avatar
Not sure how close the '69 hinge is to the 72, but if they look alike, then the procedure would be the same.
You may have to grind off the retaining tabs off the bottom of the pin. A dremel tool works best.
This might help you...
https://classicoldsmobile.com/forums...tml#post155187
Old Jan 29, 2012 | 05:07 PM
69postman's Avatar
Ok thanks that helps!!
atkinsom
Nov 9, 2012 09:53 AM
Redog
Aug 14, 2008 06:56 PM
bear71
Oct 22, 2007 02:00 PM
dyscookn
Feb 16, 2007 12:24 PM
polcatt
Oct 8, 2006 07:03 PM
