71 Cutlass center console door hinge
Old Oct 18, 2007 | 03:44 PM
bear71's Avatar
Awhile back I leaned to hard on the center console door and broke the hinge away from where it attaches to the inner box liner. I bought what I thought was a new inner liner but it turns out it was only the two-piece floor. Does anyone know if I have to seek out an entire new center console---if so, what's the best way to pick one up? The OPG/Year One-type outfits don't have them. By the way, I've tried every glue/cement imaginable to try and fix it myself.
Old Oct 19, 2007 | 05:00 AM
Oldsguy's Avatar
Past Administrator
did you try epoxy resin with fiberglass mat on the back (bottom) side to repair it? I would think that would work.
edit; never mind, I see that you broke the HINGE. Sorry.
Old Oct 19, 2007 | 08:17 PM
2blu442's Avatar
Center Console
Bummer! yes this is a common place for them to break. I've got a couple in the garage with the hinge mounting points broken. If you could find one for parts it would be cheaper than buying a whole assembly just because this broke! I think ebay would be your best bet as I've seen a couple on there every week, but one for parts may not come along as often. John
Old Oct 22, 2007 | 10:11 AM
bear71's Avatar
Center console hinge mount
Actually broke the hinge MOUNT---maybe the epoxy resin with fiberglass will work to cement the mount points back to the inner liner of the box.
Old Oct 22, 2007 | 12:17 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Now is your chance.....
to weld up a cooler one!
Old Oct 22, 2007 | 01:58 PM
Oldsguy's Avatar
Past Administrator
Bear, yeah you have a chance then. Completely disassemble that sucker and be very generous with the epoxy. It can be filed and sanded later if you got too much. Good luck.
Old Oct 22, 2007 | 02:00 PM
bear71's Avatar
Will give it a shot thanks!
HWYSTR455
Sep 4, 2022 07:23 PM
KenOlds442
Jun 10, 2015 05:01 PM
slowolds
Oct 5, 2010 12:02 PM
cbogartjr
Mar 3, 2010 07:33 AM
bear71
Mar 27, 2007 08:59 PM
