Deck Filler Panel & Deck Lid Fitment
Old June 8th, 2016, 10:20 AM
gbledsoe3's Avatar
Before I weld in the replacement deck filler panel, is this height difference Something I should tweak first? The mock-up trunk lid is slightly higher than the filler panel in the center.
gbledsoe3 is offline
Old June 8th, 2016, 06:35 PM
therobski's Avatar
On picture 2 the trunk lid edge looks like there higher too. Is the old trunk weather still on the car or a new one? Looks an early A body car? I have tons more of pics I can send on my 64_85 Pro-Touring. I needs to fit or it will leak even after to install the new weather strip.
therobski is offline
Old June 8th, 2016, 09:35 PM
gbledsoe3's Avatar
There's no weather stripping, I was trying to hold the deck lid at the approximate height on the edges so it may be a little high on the sides. I wonder if I should buy some and the rubber bumpers that go on the back corners to space it up. This is a complete frame off restomod.
Old June 9th, 2016, 07:16 AM
therobski's Avatar
There are no rubber bumpers on my 64 trunk, just the hood. Good luck
Old September 4th, 2016, 12:02 AM
steveolds's Avatar
Did you purchase a repro filler panel? If so where did you purchase and what is length and width?
Thank you, Steve
steveolds is offline
Old September 6th, 2016, 06:04 PM
marxjunk's Avatar
alway fit weather strip before welding..it makes a huge diff...since the lid os low, and even..i think the strip will help a bunch
the factory uses a shim for raise the decklid..but theres a bodymans trick
you use a 2x4 under the arc of the trunk hinge and close the decklid..it pushes the decklid up..done it a million times..
marxjunk is offline
Old September 7th, 2016, 05:47 AM
gbledsoe3's Avatar
I don't recall where I bought the panel, but they are available from several different vendors including Auto Body Specialties.
ABS Trunk Filler Panel - $85
Old September 7th, 2016, 03:34 PM
therobski's Avatar
I stand to be corrected there is 2 round rubber bumpers, one on each end of the trunk lid-me bad. You see a little bit of the one in the picture
Old November 4th, 2017, 08:02 PM
salb203's Avatar
Wow, nice work and restoration on your car!
Sal
salb203 is offline
Old November 6th, 2017, 08:08 PM
cherokeepeople's Avatar
nice reel light!
cherokeepeople is offline
Old November 7th, 2017, 06:36 PM
therobski's Avatar
its an oldie but a goodie, all restored thanks cherokeepeople
Old June 20th, 2018, 07:15 AM
AJFink's Avatar
Mark
Can you send me a picture showing how you do this.
AJFink is offline
Washy1
Body work
June 7th, 2016 08:53 AM
russ0326
December 18th, 2013 07:45 PM
pitfield1
April 26th, 2010 05:27 PM
chris83
March 4th, 2010 07:36 PM
Jolly Green
January 25th, 2008 12:49 PM
Quick Reply: Deck Filler Panel & Deck Lid Fitment
