bumper question
Old Nov 21, 2012 | 01:16 PM
rocket350's Avatar
1970 olds cutlass supreme
bumper question
this is a 1970 cutlass supreme
how out of whack would u guys say these bumpers are? front and rear
rear in next post
and can the dent be popped in rear bumper?
what size of gaps should i have between bumper to headlights, fenders,hood tooth and quarters?
Old Nov 21, 2012 | 01:17 PM
rocket350's Avatar
rear bumper
Old Nov 21, 2012 | 04:29 PM
Olds_71_442's Avatar
Rear bumper looks good. It's fitted in there perfectly. I'm not sure how much trouble it will be to pop the dent out? You'll have to put it on a piece of wood so you don't scratch the chrome on the outside. But the metal is thick, so you'll probably be needing a sledge hammer of some sort to get the dent out.
The front bumper looks like it was pressed in, in the middle. It's the only explanation I can think of for having both sides pointed outward.
Old Nov 22, 2012 | 05:14 AM
DENT's Avatar
Put it in a press and push it out slowly,
Old Nov 22, 2012 | 07:38 AM
rocket350's Avatar
the front bumper was bent like that when my father was parking in the garage, he had a stroke or something and floored the gas and hit the back wall of the garage, so do u think the front bumper is saveable?
are you talking about the dent in the rear bumper?
Old Nov 22, 2012 | 08:06 AM
DENT's Avatar
Yes , sorry I didn't say so. I'v pounded them out with a hammer but the press is much kinder if you take your time. Just my experience .
Old Nov 22, 2012 | 08:32 AM
rocket350's Avatar
ok also, when i let the license plate slam closed, i see rust fall off the back of the bumper, how would i treat the rust
Old Nov 22, 2012 | 08:49 AM
DENT's Avatar
Hopefully the rust isn't to bad, I would scrape it off and maybe run a wire wheel over it. You might be able to use a small sandblaster on the backside. Then some epoxy primmer follow'd by paint?? Just some ideas off the top of my head.
Old Nov 23, 2012 | 10:01 AM
rocket350's Avatar
ok sounds good, thanks
deltas1982
Dec 7, 2014 06:19 PM
98 man
Jun 10, 2014 04:39 PM
Alex72cutty
Jul 30, 2012 06:31 PM
IDAS 69
Mar 18, 2009 03:57 PM
SX455
Jul 1, 2007 01:33 PM
