69 s convert. Quarter removal
Old Aug 23, 2011 | 06:54 PM
dreamcar41's Avatar
Hey guys just wondering for those who were brazin enough to do their own quarters, what did you cut them off with? or should i ask what is the best?
cutoff disc? air shear? air saw?
Old Aug 24, 2011 | 04:38 AM
69442C's Avatar
I used an air chissel with a panel cutting bit to do the rough cutting (works very quickly) and then used a cut-off wheel to do the fine tuning. So if you have a cut-off wheel, that should work for you.
Old Aug 24, 2011 | 04:26 PM
Eric Anderson's Avatar
I use cut off wheels. I don't know if it's the best or not but it works for me.
Old Aug 24, 2011 | 05:33 PM
oldsconv's Avatar
For trunk floors and such, I used an air nibbler that takes out crescent moon shaped chunks - very fast but works on long straight cuts. I still needed the cutoff wheel to do the bends, edges, corners, etc.
For my quarters, I actually hung new full quarters so I used a Blair spotweld drill and cut out all the old spot welds and pulled it off that way.
Old Aug 24, 2011 | 06:33 PM
dreamcar41's Avatar
Thanks for your input guys.
69oldsguy
Body work
Apr 2, 2021 07:25 PM
vistacruiser1971
Nov 9, 2013 01:19 PM
Tom442
Apr 6, 2012 05:57 PM
86 Cutlass
Apr 21, 2010 06:30 AM
