68 Convert rear of quarter molding question.
Old Apr 1, 2012 | 12:36 PM
Tom442's Avatar
I got a set of the molding for my 442 from one of the finer Olds vendors in Connecticut. I went to put them on today and find my old ones are different with a little lip to retain them horizontally while the repop ones have a little tit(He said tit!) that looks to go into a relief hole to maintain it in a horizontal position....I dont feel like drilling a hole ..just want to either grind or cut-off wheel the tit off. Has anyone done this before? I would imagine I wouldn't want to let it get to hot so as not to repaint the piece or damage the chrome? You guys suppose this would have been like a middle of the year change on these?
Old Apr 1, 2012 | 06:58 PM
2blu442's Avatar
Tom, you might be onto something with the mid-year change idea. Here's the right hand side I removed from a 1968 4 door car many years ago. John
I just checked the casting numbers and my left hand one is #8719932 which is different than your factory one. I thought both the convert and 4 door shared the same deck lid trim... I wonder if I'm wrong about that?
Last edited by 2blu442; Apr 1, 2012 at 07:02 PM. Reason: Looked at casting numbers
Old Apr 1, 2012 | 08:05 PM
Tom442's Avatar
part numbers
Thanks for the reply 2blu, I looked at the part numbers on my old trim pieces...LH7787361 and RH7787362. these are my originals and they have the lip that goes to the bottom against the lower edge of the rear of the quarter. Definately different part numbers from the old set I picked up LH8719932 and RH8719931 which are like yours and the repops. I guess I should decode my car and see when it was built.
Old Apr 1, 2012 | 08:31 PM
rcorrigan5's Avatar
Randy C.
The convertible trunk trim and the hardtop trunk trim pieces are different - all 3 across the bottom edge of the trunk. The design of the convertible trunk lid is different from the hardtop trunk lid, as are the top part of the quarters. That also explains why the power antenna unit for a '68 convertible has a different positioning on the quarter (it sits entirely on top of of the passenger quarter) whereas the hardtop power antenna piece sits on the crease of the passenger quarter.
Randy C.
Old Apr 1, 2012 | 08:42 PM
Tom442's Avatar
But ... should I cut those bumps off to mount the new repop ends??? Or drill some more holes in my quarter? I am TORN!
Old Apr 2, 2012 | 12:55 PM
firefighter5174's Avatar
I got 2 68 hardtops sitting at my house right now. 1 has 2 holes on each side for the extra "bump". The other only has the 1.
Old Apr 2, 2012 | 01:32 PM
rcorrigan5's Avatar
Randy C.
If I had to choose, if your trunk lid doesn't have the holes, I'd grind off the bump on the trim piece. It's so much easier replacing the trim pieces in today's world (with the repops) than it is replacing an entire trunk lid. Just my personal opinion.
Randy C.
Old Apr 2, 2012 | 02:17 PM
Oldsmaniac's Avatar
I am not an expert but that bump may be there to give a tilt to the emblem or make sure it mounts at proper angle?? Did you try to mount it and see if it will work with it on there?
Old Apr 5, 2012 | 08:20 PM
Tom442's Avatar
Yah. it definately goes into an extra hole that must've been on some of the 68's. It doesn't sit flat against the quarter. I sent mine to a plater in Yuma Colorado today to get an estimate on replating my originals...if the estimate comes in reasonably..I will have them plated. If not, I will cut off the positioning nub and see how it fits...maybe a little two sided trim adhesive. Thanks guys for all your help. You are genious!
Tom
Old Apr 6, 2012 | 05:57 PM
allyolds68's Avatar
My car had the extra hole. My car was built the last week of April. If your car is painted (& im pretty sure it is) I'd grind off the tit. I had to do some grinding and opening up holes in the rear 1/4 for the peak trim & it killed me to do it.
Of course my car is currently being completely repainted (again). But that's another story to come.........
CLcutlass
Jun 9, 2014 04:31 AM
vistacruiser1971
Nov 9, 2013 01:19 PM
mikealandrum
Jun 4, 2013 06:16 AM
tecar442
May 21, 2009 07:59 AM
